I have a Delta 14" bandsaw with a 1HP motor. I am wondering whether I can change the motor to 2HP to give this bandsaw more power. Will the frame strong enough to take a larger motor?
A larger motor will help some. Part of the problem with the smaller bandsaws are the lightweight wheels. The better larger bandsaws have heavy cast iron wheels which have a flywheel affect. The extra rotating weight helps pull the blade through tough spots that bog down the lightweight aluminum wheels. I had an older Delta 14" with a 1 1/2 HP motor. I sold it and got a 20" Agazzani with a 2 HP motor. It has heavy cast iron wheels and there is no comparison. You cannot bog it down. You might also try a 3 teeth per inch skip-tooth blade. When cutting thick wood, especially when it is wet, the saw dust builds up in the teeth and kerf and bogs down the saw. Fewer teeth per inch help clean the kerf so the saw dust won't build up.
You may find that the pulley sizes will not allow the extra power to be transmitted to the V-belt(s). In other words the belts will slip. I had that problem on my Asian bandsaw with its original motor on it's slowest speed because of a very small diameter pulley.
Iturra has a wonderful catalog that is more like an owners manual. Unfortunately he does not have a Web presence and I don't have his phone number. In that catalog he discusses increasing the motor size and increasing the speed of the blade. So, Whether the frame is strong enough or not, many have done it. I have a similar saw and I would also like to increase the motor size. But, I think it would be a good idea to double the motor size and increase the blade speed by about a third. So, I would have to buy a new motor and a pulley. But then that motor should be a 240 volt motor rather than the 120 V that is on there now. That means a new circuit, but my panel box is full. If I somehow got a new circuit, it would mean an new switch and writing for the saw. The more powerful motor would probably benefit from double pulleys and twin belts, so I would have to buy those in stead of the single pulley mentioned above. I doubt the present belt guard would house the double pulleys, so I would have to make or buy a new one. If it were as simple as throwing anew motor on it, I might do it, but once I think it through, it gets complicated.
I have already added a tension release, Carter guides, the riser block, a better spring, dust collection and brushes that keep the wheels clean. I would have been cheaper to buy a larger better equipped bandsaw to start with.
Sombody Post Itturra's Address and phone number Please.
I have a band saw that resembles that -- 10 year old delta with progressive upgrades and accumulated costs greater than if I had purchased it all together -- the curse of cash flow limitations. I have the riser block installed and that does make a difference in stiffness of the system.
I run 220 volt on my 1 hp (5 amp 220v) motor. Change the connections on the motor and change the plug on the cord.
Memory is that the motor is a Type 56 frame and mount. That is an easy change to a 1.5 or 2 Hp motor. And the same cord and switch are already sized for 10 amps just that it will be 220 volt now.
The challenges of power transmission and torque have kept me from going there. There are a lot of moving parts and friction energy transfer points.
Better management of blades, fewer larger teeth on blades, and careful feed rates have me working successfully so far.
2 HP with 220 volt variable frequency drive might be the rolls royce engine in a volkswagen body -- but could be done.
Hey Berry if your power panel is full but not overloaded you can change out your breakers to TWINS . This will add open spaces for the 220 breaker you may want. Or just add another sub panel.
Thanks, but I already have twins. Lots of them. Not sure there is room for more, but there might be. I have been thinking about running the band saw on the same circuit with my TS which is already on a 240 circuit. Its a 30 amp circuit dedicated to the TS. That motor is already a 2 HP. Anybody know if it is acceptable to run two tools on the same circuit? I almost never run them at the same time.
My tirade was just an example of going through life "But First". I would put a bigger motor on my BS, but first...... Sometimes these things add up...
Not all panels are rated for twin or half-size breakers. Sounds like Barry's is, but I can tell you how quickly a panel can get filled up; when we did our bath remodel last Fall, I had to switch out the subpanel that serves the house because we needed to add a circuit, and it was full full full.
Now adequate room for the projected expansion as we continue remodeling, and room to spare after that.
