THE WOODRAT IS BACK!
Woodfast on to it's new home
Molly Winton
Barb and George came this afternoon to pick up her 'new' lathe. Barb's son also showed up to provide some much needed muscle. Once George figured out how to remove the belt, we took her apart and they muscled her into their truck. They oughta be home right about now trying to figure out how to unload her.
It's always a treat to put a face to someone's name, and this was no exception. It was great meeting all of you Barb. I hope you enjoy your new lathe.
Re: Woodfast on to it's new home
Barb Siddiqui
Barb Siddiqui
Thanks, Molly. It was nice to meet you and your son, also. At least we gave you some more space! The loading in was the harder part. My new lathe is now safely unloaded and floor-leveled. We just have to go get a small tap tomorrow to re-cut the threads on one set-screw on the headstock handle, and then I can turn the thing on. George and I were alone to unload it, but we propped the pick up tail gate to support it, slid the heaviest part out and tilted it slowly downward, back end first, onto a pallet, then straightened it around and slid it into position. The ways of the lathe bed with headstock attached were unloaded separately and bolted in place on top of the base. Figuring out how to break it down into two pieces was the key over at Molly's house. Whew, tired, but what a great day.
Carol Reed, Strawberry, AZ
Pictures??
I am so happy for you!
Barb Siddiqui
Simple Green, a little steel wool....
Barb Siddiqui
and voila! I cleaned it up (at 0630 this morning,) waxed the bed ways and underside of the banjo and tail stock. Everything slides smooth as silk. Ain't it pretty?
Re: Simple Green, a little steel wool....
Don Wilcut
Congrats! Years of enjoyment await you.
Don :)
Molly Winton
She looks happy as a little clam! Glad you made it home safely, and got it unloaded easily. I'll be looking forward to seeing what you make with her.
Re: Barb, make sure that ...
JamieDonaldson
.....the alignment from spindle point to tailstock point is still accurate after all this disassembly and moving. This is a wonderful lathe, and the move up from a mini will set you FREE as a REAL creative turner!! Enjoy!! I still use my older Woodfast frequently, and would not even consider parting with it when Studly the Stubby came into the shop! :D
Carole Valentine
Congrats Barb! Now get turning...that lathe already knows what to do...Molly trained it well. :)
bill crommett from Seneca
Barb: It is always good to hear that someone has unloaded a great piece from the truck and not ended up with a bunch of mangled Iron and steel.
Barb Siddiqui
Or
Barb Siddiqui
mangled feet! All it cost me was a small cut and bruise on one forearm, no crushed fingers or anything. Very proud of us! Today I took time to build/set up a small work station behind it with a rack for holding gouges, and shelves for accessories. I really cannot stand working somewhere without a secure place to lay tools down where nothing will get damaged. Now that that's done... tomorrow I can turn. Thanks to everyone for the advice and ideas. Oh, and I tested the alignment today; hadn't thought of that after transporting it. That lathe is solid as a rock. Perfectly aligned. I'm So glad I did this!
Re: And we're glad for you-enjoy!!!!
JamieDonaldson
