Stabilizing Pen Blanks
Andy Lincoln,in Dearborn MI
Hi All,
I had some success making the 0.9mm pencils after the info provided here.I bought a mandrel,
bushings,and step drill bit from The Perfect Collection .I was able to successfully turn two pencils.
While shopping on Ebay where I found the 0.9 Pentel Pencils for less than $2ea delivered!!,I stumbled upon some spalted wood blanks and purchased those.Today they arrived. My plan is :
To use Minwax Wood Hardener to stabilize the blanks.I plan to pour the MWH into a plastic container that came with my vacuum sealer.It will hold 6-8 blanks and has headroom/space to vacuum the air out.
I plan to let them soak for 1-2 days and then air dry for 1-2 more days before beginning to turn.
Should I drill a center hole in the blanks before I stabilize them?Is the vacuum needed/necessary?
Can I reuse the MWH if I pour it back into its original container?Should I spray a product like Bloxygen on top of the MWH when storing it?
It there a better/easier/neater/simpler method????
Thanks,
Andy
Re: Stabilizing Pen Blanks
Jim Sebring
I've used MWH on some very spalted Birch by soaking for several days in a closed container. I let the blanks dry for several days to make sure they were fully cured. I saved what wasn't absorbed by the blanks. I found no need to use Bloxigen. I think this wood hardener is little more than very thin polyurethane.
Cgelnett
I use an in-expensive preasure cooker and instead of putting preasure on the container I take the weight off the top and connect my vacumm pump. The connector is the same size as my vacumm hose. Put the solution in a container inside the preasure cooker and the wood inside the container.
At first it is floating and after about 30 minutes it is completly submerged.
Chris Stolicky
I have not attempted to stabilize any pen blanks, but I would not recommend pre-drilling them. If the wood moves, swells, or shrinks at all, you are going to have difficulty getting the tubes in.
