Gouge removal
Gouge removal
Steve Kubien
Gouge removal
Steve Kubien
Morning everybody.
So, Mr. Postman showed up today to deliver my new 1/2" x 16" long Thompson Lathe Tools handle. Now I need to get my 1/2" U-gouge out of its existing handle. Problem is, it is epoxied in. Suggestions? Do I just cut through the copper pipe ferrule and start knocking it around? I know I should have ordered an extra gouge but funds are tight. They will be ordered as matching sets in future!
Thanks!
Steve
Re: Gouge removal
Heat....
It does not take a lot of heat to destroy most epoxies. I'm thinking something like 150 degrees, but certainly well below anything that will damage the gouge. It is one of the HSS ones isn't it? If its one of Doug's ask him. I would heat it with a torch just above the ferrell and then put something like a wrench on it around the shaft and hit the wrench. This with the handle hanging down and the gouge clamped in vice.
Re: Gouge removal
Re: Gouge removal
Bill Howatt
Like Barry said, a bit of heat usually significantly weakens epoxy but the metal may be well jammed into the handle.
You could also mount the old gouge on your lathe, with the handle in a chuck or a spur center on the end of the handle. Make a big "dowl" with a piece of wood and a blind 1/2" (?) hole in it for the metal gouge to sit and bring up the tailstock. You can then turn off the copper and wood with another gouge.
Bill
Re: Gouge removal
Re: Gouge removal
Steve most of the time I can clamp the blade in my vise (with wooden jaws to protect the steel) and then I put a big crescent wrench loosely over the metal and hit it with a dead blow hammer. Most of the time that knocks them loose.
If that doesn't work or seems excessively hard, and I do hit the wrench pretty hard, then I heat the tang just in front of the metal. I put a pair of vice grips loosely on the blade to absorb any heat that wants to head in the blade direction. That and the Deadblow has worked every time.
Re: Gouge removal
Steve Kubien
Thank you
Steve Kubien
I figured heat was involved but wanted to be sure. Once lunch has been served, I'm off to the shop!
Re: Gouge removal
Re: Gouge removal
robo hippy
Keep the gouge in that handle, and get another one or two for the new handle.
robo hippy
Re: Gouge removal
Re: Gouge removal
Emmett Manley, Lakeland, TN
As one who has removed many a golf club head epoxied into a steel shaft, a small torch does the job quickly.
Re: Gouge removal
Steven Antonucci
Same as John!
steven antonucci
Grip the gouge in the wood lined jaws of a bench vise, and then use a mallet and a scrap of wood to drive it off. The shock of the blow usually unseats the epoxy and I can twist them off by hand after that...
S
Re: Gouge removal
Re: Gouge removal
Randy Gleckler
Okay... I read this whole thread hoping to find out how to remove those gouges I put in my bowls when I get a catch, and not a single person offered help. Huh.... Guess I just keep making smaller bowls. :-D
Re: Gouge removal
Steve Kubien
Re: Gouge removal
Steve Kubien
These folks can probably help you with that. Me, I'm not so sure. :)
Re: Gouge removal
Steve Kubien
That makes too much sense
Steve Kubien
Except in terms of my wallet!
Re: Gouge removal
Re: Gouge removal
john lopez
Immersion in boiling water is a method I sometimes use.
After it cools enough to touch a visew grips & the padded bench vise.
Re: Gouge removal
Joe Fleming
Re: Gouge removal
Joe Fleming
I use my bandsaw to cut parallel to the tool as close to the shaft as I dare. About 4 parallel cuts, then a cross cut behind the tool to remove the bulk of the old handle. Then, I use heat or whatever to remove the rest. I have, on occasion, used my grinder to remove bits of glue to get the bar round again so it fits in the new handle. Joe Fleming
Re: Gouge removal
Re: Gouge removal
Scott Hurley in N VA
Also, if you leave your golf clubs in the trunk of your car on too many hot days, one day you may be able to watch the clubhead go farther than the ball...
Scott
