Please advise how I can remove a Jacobs taper X #2 MT mandrel already mounted to a drill chuck. I need to replace it with a JT X #3 MT. Also, are there any suggestions where to purchase the JT X 3# MT mandrel ?
I should have mentioned that the arbor does not have a machined flat area to grab with a wrench, but it does have the circular recess between the JT and the MT.
Mike, it would probably be faster, easier, cheaper, and just as accurate to obtain a #2-#3 adapter and stick it on the end. That is what I have done for mine.
possible to drive a wedge of some kind behind the chuck? Like a tapered fork, or "pickle fork", used to remove automotive ball joints.
Or, there should be a center hole for a mounting screw, to screw into the end of a threaded mandrel--probably around 5/32" or 3/16" diameter. Block the chuck up with the mandrel hanging free and hit a pin punch into the hole. Good place to shoot penetrating oil into as well, do that whatever method you try.
A Jacobs taper should be easier to release than a morse taper, it has a deeper angle.
Failing the first two methods, try the shock method--repeated whacking the chuck on it's back end while holding the mandrel in your fingers. Watch your knuckles!
You can find any JT you need at Enco or McMaster-Carr. I recently replaced the chuck on my old Delta drill press, #3, which came already installed in the new chuck. They sell a tapered wedge for that purpose, but I don't know how you would get the taper out of a chuck once installed without damage, as there is nothing to grab onto. One thought: drill and tap a hole in the taper you want to remove. Thread in a bolt, and tighten it, forcing the taper out.
It's possible the taper is threaded into the chuck. (I doubt it) If it is threaded, it would have to have a locking screw to keep it from unscrewing when you run the drill backwards. Open the jaws fully and look in the bottom of the chuck. If there is a screw, remove it. Then unscrew the manfred from the chuck. (I seriously doubt this is what you have.)
I removed the chuck on my DP. I took tow cheap wrenches and ground them to taper on their faces. The wrenches were whatever size just slipped into the shaft of the DP. Then I used two hammers to drive them toward each other and wedge the chuck off. Nothing happened until it popped off all at once. I thought I was a clever fellow until I discovered that you can buy two matching wedges made for the job. I suspect they will fit right into the slot on your mandrel.
Having said all that, I would go with Bill's suggestion and buy the adapter.
If you want to remove the mandrel from the chuck. Just open the jaws and place mandrel between the jaws of a vice, take a punch and place it in the opening of the chuck jaws and whack it with a hammer not a mallet, a hammer. Do not tighten vice jaws. Be ready to catch it. I do this all the time because i want to use the 5/8th" chuck in my DP sometimes on my lathe and i need the threads for a draw bar. Carl
Carl has it right. Just whack the taper out from the business end of the chuck. MSC has replacement mandrils.
The #3 to #2 adaptors work fine if you don't stress the chuck to much. If you want to take advantage of the power that a #3 MT is designed to deliver the replacement of the mandril is the way to go.
the MT3 to jacob taper are also available from Little machine shop. They have some on sale for about $4 -- Most of these come drilled and threaded for a drawbar, though some are threaded M10 (I drill and tap a stub of an M10 bolt to 1/4 by 20)
Note that the 3JT is probably the most common chuck, but there are several other tapers around. The side or bottom of the chuck usually tell the taper (or thread or straight shaft size etc).
For the open bottom chucks, the punch and hammer approach is effective. I use the open jaws of the bench vise to hold the drill chuck and tap (hit) the adapter out. Clean the recess and remount the drill chuck with the new MT3 JT adapter.
There should be a recess in the shaft just above the chuck. There are wedges made to go into that recess to remove the chuck from the JT part. There are 2 wedges in a set and you put one in from the right side of shaft and other in from the left side, one wedge riding on top of the other, pressing them together will remove the chuck without damaging anything. This probably will have to be done in a vise closing the jaws against the wedges.
So you need to remove the MT from the drill press first and that is done with what is call a "drift key". Turn the handles just as you would when drilling and note the slot that appears in the column that comes down out of machine, you may have to turn the chuck by hand while looking through the slot and you'll see the end of the MT. You places the drift into this slot above the MT and let the quill back up into the machine, when the drift hits the head pull down on handle inch or so while holding the drift and let it bang up with the spring you've also got to catch the chuck at same time as it will fall out when drift hits the bottom of the head.
You can buy wedges and drifts at mscdirect.com, enco or mcmaster and carr and other industrial supplies. They also sell the JT x MT's in different combinations.
correction to my wording above, when you place the drift key in the slot, I mean to say DON'T let the thing hit the head as it may make the chuck fall out.
You should let the thing back up so the drift key is touching the head of machine and it is holding the column there, THEN hold the chuck with one hand and gentle tap end of drift key with small hammer driving it into the slot, this will force the MT out of machine.
