ISO accurate scale to weigh turning blanks
ILYA Z
I have some green turning blanks that I want to dry. I'd like to measure the progress by weighing them periodically. What I need for this is a scale that both (i) can weigh large pieces and (ii) is very accurate. Not sure how accurate I actually need it to be, but I don't think any of the regular "bathroom" scales that satisfy (i) are good enough. At the same time, various kitchen scales that I saw can measure accurately but have around 10lb weight limit. Has anyone found a scale that is both (i) and (ii)?
Thanks much!
Re: ISO accurate scale to weigh turning blanks
Make It Easy (and cheap)
Weigh your blank from time-to-time on the same scale. When it stops losing weight, your wood will be as dry as it's going to get for your location.
[that'll be 5� please :D ]
Re: Make It Easy (and cheap)
ILYA Z
That's exactly what I am going to do. However, since it will be losing water slowly I need to be able to see small changes in weight. I will be trying a fast drying method so I will need a way of telling whether it's working or not.
Just did a quick search and found these  *LINK*
http://www.americanweigh.com/
Re: Just did a quick search and found these
This one might work. http://www.americanweigh.com/product_info.php?cPath=57&products_id=99
However they have so many I believe I would give them a call and just tell them the weight ranges and price limit and I'll bet they can tell you a model that will work.
bill crommett from Seneca
I have been doing quite well with a postal scale I bought at Staples.
Try
A used restaurant supply house. Think what you're talking about is a hanging scale that will go from 0 to 100 lbs in 2 rotations of the dial. You don't need anything "legal for trade", but a commercial portion control scale should do fine. You may even find one that's adjustable so you can zero out the sling or bag that you put the wood into to hang it.
The bigger the dial, the easier it will be to see changes in weight.
John Leonard
I got6 a postal scale that goes up to 70 pounds at Harbor Freight for $39.99 (I think). Works fine for me. John L.
v
Check on Ebay for a scale that weighs up to 75lb. I got mine for $14.50 and it works just fine.
Bill Grumbine (Kutztown PA)
I had a conversation about this very thing with a student today. I told him that either the blanks stayed around in the barn so long it did not matter, and I did not have to worry if they were dry, or I needed one bad enough that it did not matter and I did not worry if it was dry enough. So, I don't bother with a scale. :D
fgvanatta
A digital bathroom scale. Most measure in tenths of a pound, which should be close enough. I use one to weigh people, packages, and wood.
Dave Moore
I bought a scale at, I think, Bed bath and Beyond or some place like that.
I don't use it much for weighing wood, just now and then, but use it all the time for baking bread.
Anyway, it will weigh up to 40 lbs, it's accurate to 1/10 of an ounce, and it cost less than $25.
Charlie Anderson
A non-weighty answer from a weighty person! :D
Bernie Weishapl
I bought a postal scale off ebay that weighs from 0 to 55 lbs. It weighs in 10ths of a oz. I think it cost me around $20.
Stanley Townsend
I don't know how much rigging you want to do but you could use a 10 ft 2 x 2 and place a load platform 1 foot from one end and put a sharp fulcrum under the very end of the 1 foot side. Put a point (nail) on the scale end and presto you have a 10 to 1 scale.
D. Hansen
you can get a postal scale that will wiegh up to 70#'s in .00 levels on ebay . Usually run about $30
Harbor Freight is your friend....
Ralph Lindberg
... when it comes to cheap tools, when you don't need expensive ones.
I have both the 70 lb and smaller 20lb scale. Most of the time the 20lb works just fine
John Altberg
This is the scale that you want. I have one at the office and one in the shop. Has lbs, oz, grams & kilograms. I weigh my blanks with the gram scale.
http://www.amazon.com/ULTRASHIP-55-DIGITAL-SHIPPING-KITCHEN/dp/B000FSWB9K/ref=sr_1_6?ie=UTF8&s=office-products&qid=1278715431&sr=8-6
Greg Burnard
I've been using a baby scale for many years. Large platform, accurate, cheap at flea market, yard sale.
