Optivisor - What magnification?
Andrew Bourke
Hi All, I am considering adding a Optivisor as a means to finish off my turned & carved articles better.
I see that there are a number of different magnifications and working distances with the lenses that are available. What would be a "general" sort of choice? If you use one what do you have and would you change it for something else?
Re: Optivisor - What magnification?
Donna Banfield
Andrew, I have two lenses, numbers 5 and 10. The power translates to 2.5 for the #5 lense and 5 power for the #10.
The 10 has the greatest magnification but your work has to be almost at the tip of your nose for it to come into focus. Not exactly a comfortable working distance. I use the 2.5 power lense most often, the focusing distance is about right - the distance between my eyes and the piece being held in my hand on my bench as I work.
Terry Scott
Hi Andrew
I agree with Donna 2.5 is good
a consideration is if you already use prescription glasses
I have just had to get Glasses (not liking it one bit ) and found I have had to alter my magnification on the vision head set as I was getting double vision and reflection between the two
I am also hating the glasses because I can know see scratches et.c in my finish
Re: Optivisor - What magnification? *LINK*
I agree with Terry, my bowls look a lot neater without my glasses. :) I use a 4 mostly but it depends on the project. a 2.5 with my glasses lets me work with a piece a little above elbow height but of course the magnification is less. The 4 lets me work about half that distance which is actually uncomfortable but does let me see the smallest detail. I would not use this lens if I had to work for very long, the 2.5 would be better.
I prefer the style below to the solid headbands. It lets me position the lenses exactly where I need them. If you wear glasses this is critical because it changes how you hold your head depending on whether you have to look through the bifocals or upper halves to get the magnification you need. They are also lighter and more comfortable. RioGrande has all styles and sizes of lenses so you should be able to find exactly what will work. They used to have a chart that showed the working distance but I didn't look to see if it's still there.
http://www.riogrande.com/MemberArea/ProductPage.aspx?assetname=113877&page=GRID&free_text|1278675044293=magnifiers
Keith Newton----Little Rock, Arkansas
First, let me chime in and say that I like the #5 best.
I have been using the same Opti-visor for probably 25 years, and have bought probably 5 of the HF ones for when I misplace the other.
The lights seemed like a good idea, but then, the battery shorted in one, and got hot enough to smoke. The other added too much weight, for the little hinge to manage, leaving it to sag down to my nose. Even without the weight of the batteries, the others didn't hold their position.
I depends on how long your going to wear the thing and how well it adjusts. the plastic spring tension ones that I like fit very comfortable, weigh almost nothing and are very easy to adjust to the position that works best for you.
I have a more expensive model that looks a lot like the HF and can't stand to wear it for any length of time. It's not even battery powered so it's lighter. The solid headband gets uncomfortable.
I like to adjust mine so I can look over the top to see either distant objects or to view the work further away. You can't do that if it has the shield over the top. the shield is good if your working in a situation where the overhead light puts glare on the magnifier but I've almost never found that to be a problem.
