can I save this can of salad bowl finish
ILYA Z
I have an almost full can of General Finishes salad bowl finish that I did not close properly last time I used it a couple of month ago. As the result I now have thick film on top (see the lousy cell phone photo). The instructions say "do not thin". Can I save at least some of the that finish or should I just toss the can?
Also, since the original lid is pretty banged up, can I store whatever finish I can save in a regular glass jar with a tight lid? Would a metal lid from a jar of pickles be good enough?
Thanks!
Re: can I save this can of salad bowl finish
Bill Howatt
It's hard to say just by looking at the picture and your description. If there is a thicker part on top then I'd save what's on the bottom and I never have trouble adding a bit of thinner to any oil-based finish BUT don't over do the thinning.
After you extract the finish you want, apply it to a test piece. It should go on smoothly and it should dry normally. If not then forget it.
You can put it in jars with lids but be warned the lid will likely get difficult to remove from spilled finish on the threads. I always buy some different sizes of empty paint cans to have available for such things and also for home-brew finishes or just keeping smaller portions of finish well-sealed while I use the finish.
Bill
Skim the gelled part off
That finish looks to be a rather conventional urethane varnish. I think the un-gelled portion would still be usable. Try it and see.
John Veerkamp
If you use a pickle jar lid, to keep it from sticking as bad, put a clean piece of plastic wrap over the threads before closing. it also has the benefit of providing a good seal.
bill crommett from Seneca
AND: before sealing the can/jar take a big breath, hold it for a while, blow out six ounces, and blow the rest of it into the jar/can to displace the oxygen. This is the country boy's version of BLOXIGEN.
Ric Taylor
Ric Taylor
With luck, it will be just like the gelled film on Waterlox. Just use a pipette to stick through the gell, and suck the good fluid up from below the gell. Either squirt it directly onto the surface you are finishing, on to a rag, or into another container.
With this method, I can use Waterlox out of a jar for two to three years with no problems.
Ric
ILYA Z
I ended up tossing it. The entire contents of the can were like Jell-O and applying thinner did not help.
Still, thanks to all for the advice.
woodspinner
That is what I would have done in the first place
