Not BP
Not BP
Not BP
I have a 6 CFM oil-lube vacuum pump for my lathe which was highly recommended. What they didn't mention, however, is that an oil-lube vacuum pump will throw oil if air is allowed to get sucked through the pump. Since turning as all about using varying amounts of vacuum, but never "hard" vacuum down near 30" of Hg., I'm going to have to fit my pump's exhaust port with an oil coalescing filter. I just checked McMaster and they want nearly $100 for a small oil removal filter. This is starting to get expensive.
Anybody got a cheaper/better source for this kind of filter?
Re: Not BP
Re: Not BP
charlie belden
The vac pump I have that uses oil has a hemispeherical bell above the exhaust port on the top of the "vanes" part of it
The housing case has basically a large counter sunk hole - with two legs coming off the side and a nut where they
join. The bell has a small bolt in it that allows it to be screwed into the "nut". Any oil kicked out of the pump hits
the underside of the bell and falls back into countersunk sides of the opeming above the oil resevoir.
I'm guessing that one of those counter top Ding bells and a little creativity with some fittings and you could make
something like this. Worth a try?
Re: Not BP
Nope
The pic (small, you're not going blind) illustrates. The exhaust goes out through the handle to the rear. I've tapped the handle with 1/2" NPT and can pipe from there to a filter, but recirculating the oil is not happening here.
I thought about doing a condenser as I did with my a/c compressor system, but that's not feasible with the space I have to work with now so a store-bought appears my only option. McMaster's got one that removes down to .01 micron and .008ppm. Suddenly my $200 vacuum pump is not looking like quite the deal I thought it was.
Re: Not BP
Re: Nope
steve worcester
I had a similar pump and just put a hose on the exhaust end and put the hose into a coffee can filled with paper towels.
On mine, it wasn't exhausting but a few drops during use.
Re: Not BP
Thanks + McMaster Cudoes
Steve, I decided to call McMaster as they have a number of oil-removal filter listed. Wound up speaking with "Joe" in customer service. After I explained my problem and need, he put me on hold while he tried to contact several of the makers. He came back on, explained that techies had gone home, and then proceeded to write me an order for a filter with the understanding that if it didn't do what I needed, they would pay for the return shipping or simply cancel the charge.
These guys are, indeed, nice to do business with.
BTW - tried the coffee can condenser; wasn't working out. If this filter fails, I'll just run a piece of hose outside as the exhaust.
Re: Not BP
Rob Wallace
Re: Thanks + McMaster Cudoes
Rob Wallace
Mark:
You can make your own oil exhaust filter using sweatted copper fittings, and a few threaded fitting components, all of which can probably be obtained at a good plumbing supply or a local HD/Lowe's.
You place a few pieces of stainless steel "scrubbies" inside the pipe to act a condensing surface for the air-suspended oil particles in the exhaust., and use gravity to return the condensed oil back to the pump. I've made few of these over the years on oil-jacketed vacuum laboratory pumps - didn't feel like spending the $ 80 to $ 150 each for the manufacturer-made versions.
If you'd like more details about making one of these, contact me at your convenience.
Rob Wallace
Re: Not BP
Re: Thanks
Rob,
I've tapped the handle/exhaust port for 1/2" NPT and made up an extension that ends in a union. The filter just arrived and looks like it'll fit nicely so I'll see how it does. Checked with the vendor and determined that a recirculating condenser would not work as the oil res is supposed to stay closed, plus they weren't happy with contaminants or condensed water being added back into the unit. I can still make a line condenser and a drip cup if the filter's not enough.
Thanks again for the suggestion.
Re: Not BP
Oil Free Lives
Worked up the adapter with 3-point support, brazed and sweated it together, mounted the filter, turned on the pump wide open for max air flow, and held a tissue to the exhaust side of the filter for more than a minute.
No oil on the hanky.
Mark's a happy turner.
Re: Not BP
Re: Good show old man! I love it...
JamieDonaldson
...when a Rube Goldberg plan comes together and actually works! :D
Re: Not BP
Re: Oil Free Lives
George Van Beynen
Glad you found something that worked Mark. I gave up and piped my exhaust outside.
Re: Not BP
A Materials List
and pic will be posted soon. ;)
Re: Not BP
Re: Hey, Rube!
This being the precisely engineered and meticulously fabricated piece of, ummm, Yankee Ingenuity that it is, I can almost hear Mr. Goldberg muttering, "But it's not supposed to actually do anything useful . . ."
Was kind of bummed though. The chromer wanted way too much to plate the Thing so I'm just going to have to settle for several coats of Candy Apple metalflake. :D
Re: Not BP
Rob Wallace
Re: Oil Free Lives
Rob Wallace
Hey Mark -
How about taking a hiatus from New Jersey for a while and get thee to the Gulf Coast to help all those 'rocket scientists' from BP to clean up the oil situation there?
Probably just have to scale-up your current project? ;)
Rob
Re: Not BP
Had This Great Idea
See, you like take a big-ass boat, maybe a supertanker kind of deal, and you turn it into a huge skimmer that suck up the surface oil and spits out the clean water. You could then just drive the thing around and off-load it from time-to-time!
But, nah, probably wouldn't work and you'd have to deal with a bunch of locals who were making big money on clean-up.
