debarking burls
debarking burls
debarking burls
bernie feinerman
I have a few small maple burls. How does one remove the bark from the burls while leaving the wood undamaged?
Re: debarking burls
Richard Allen
Pressure wash
Richard Allen
Pressure wash
Re: debarking burls
Re: debarking burls
Dick Coers
It's getting a little late in the season for easy bark removal. I always soften it up a bit with direct hits with a hammer. It will break the bond at the soft cambium layer, and pry it off with some big screwdrivers. I once had a big bunch of siberian elm burl that I wanted to remove the bark. I bought a small pneumatic jack hammer at Harbor Freight. I cut off the end of the chisel so I had a blunt 1" diameter rod that hit the bark. It worked like a dream. I pressure wash after removing most of the bark, but never had much luck removing the tight bark with my 2900 psi washer.
Re: debarking burls
Re: debarking burls
IAN
lathe and 1/2" bowl gouge always worked for me.
IAN
Re: debarking burls
Re: debarking burls
Terry Scott
Put it on the lathe and wind up to 3000 rpm
Seriously I just water blast them whats left i just turn off
Re: debarking burls
Re: debarking burls
Terry Scott
Seriously I just water blast them whats left I just turn off
Re: debarking burls
Re: debarking burls
Keith Newton----Little Rock, Arkansas
I have removed a lot of bark by knocking it off with a 20 oz waffle face framing hammer. Try striking the bark about 2" back from the edge across the grain at about 45�. This will sheer the cambium cells. I like to keep a spray bottle with lemon juice, to spray the surface, which keeps it looking cleaner. Otherwise, there will be a brown spot / bruise under where the hammer hit.
If there is a lot of texture like bud-knots on the peaks, it is best to use the pressure washer there. You really need to get up into the higher power ones for that to work very well.
Rather than just eroding the bark away, it works faster if you try to shoot the stream under the side of an edge, across the grain, which will blow it up and away.
Just keep in mind that the weakest property of most woods is tension across the grain. Try to use that to your advantage.
Re: debarking burls
Dick Hines
Re: debarking burls
Dick Hines
I usely turn the bowl in the shape I want and then take a pair of channel locks and break the bark off. Most of the time it works good.
Re: debarking burls
Re: debarking burls
bernie feinerman
Thanks for all your suggestions. I was holding back on the 1/2" gouge and "away we go" approach for awhile so as to get a feel for what was under the bark. The bark thickness varies from 1/16" to 3/4" which makes it interesting.
I have a hammer, pick, and chisels and will explore pressure washing.
Re: debarking burls
Yes but sometimes,
If you have a nice burl with the right shape and wonderful texture that would make a wonderful hollow form, those elements may be lost under thick bark, but would be revealed if stripped first.
