Do these kits exist?I like using 0.9 mm lead pencils in the shop and with my new lathe I'd like to turn a couple pencils for myself.I did turn a couple 0.7's but my ham hands don't respond to fragile lead very well.
I haven't seen any. I've looked as well since I really liked the old cross 0.9mm twist pencil. Can't find anything in a kit that is 0.9mm. There are a couple of kits that use larger lead (5 mm or so and I think there is a kit for 2 or 3 mm). I have a couple of those for the shop. But they don't create a fine line if you want precision.
Here are some mechanical pencils done using a process that's been around for many years. The 'innards' from commonly available Pentel mechanical pencils are used to create custom pencils from materials of your own choosing. A step drill (the one shown is 17/64 with a 1/2" long 'step' down to 1/8") is used to drill the blank, which is slipped over a pen mandrel for turning. Shown from left to right are: The Pentel pencil (9mm for my heavy hand, but you can use any lead size--they all work), the step drill, and pencils in Cocobolo, Padouk, Bloodwood and Corian. Not that anyone needed anything else to turn.....
Incidently, these pencils cost an arm and a leg in office supply places. I give these out to clients and architect and engineer friends so I bought several dozen on line a few years ago for less than two dollars each. I'm sure prices have gone up but check around for quantity deals.
Pentel pencils like this were what was done in the thread I mentioned on the other forum. I like the idea of having a 0.9mm pencil but what I really want is a twist mechanism pencil. Cross used to make one. It hasn't been available for a decade or more. I have one that the clip no longer holds on. I suppose I should contact Cross and see if I can get is fixed. The problem with that is the finish on that particular set, I haven't seen in years either. So I thin I would probably wind up with-out a 0.9mm twist pencil if I sent it in.
I bought two of these drills years ago from Craft Supplies--which I don't think carries them anymore. I found a couple of places that sell them but I don't know anything about the companies and haven't ordered from them, so caveat emptor. Hope these links are permitted
You can also try making these without the step drill. Drill the blank to appropriate depth with a 17/64", then take the blank and slip it on a 1/4" drill rod mounted in a collet chuck (or use a pen mandrel). Use a plastic drinking straw split lengthwise, or a bit of scotch tape to take up any slack between the blank and the drill rod/mandrel. Use a drill chuck in the tailstock with the 1/8" bit to finish drilling the smaller hole.
The Pentel pencils are very easy to take apart. Pull off the eraser cap and unscrew the silver nib and the brass innards slide right out. The screw-on nib is what holds the whole thing together...and it will do the same thing for the new shell you create. The tip screws onto the brass threads which protrude through the 1/8" step drill hole. The rest of the 'innards' bottom out on the shoulder of the step, so screwing on the tip locks the whole thing in place.There is no need for a brass tube or any reinforcement of the wood, although once in a while I add a drop of thin CA glue to the interior shoulder area of the wood if it seems too thin.
No custom bushings necessary. Just slip the drilled blank on the mandrel until it bottoms out on the shoulder where the hole transitions from 17/64 to 1/8, shim the blank with straw or tape as mentioned above and gently bring up the tailstock with a cone live center to put enough pressure on the blank to keep it from spinning on the mandrel.
Here's what the innards look like. Good luck. They are pretty easy and fun to turn and you can have a one of a kind pencil.
