"Stamp Controller" Interactive - Progress *LINK*
charlie belden
Turns out this idea of using a little micro computer "stamp controller" to do interactive pieces, that don't require actual physical contact, has a moderately steep learning curve and involves dealing with LOTS of little tiny wires that you have to keep track of and know what's connected to what (and what's SUPPOSED to be connected to what). Two Wires here, Three Wires there, Four Wires over here, a couple more Two Wires to connect over there - and pretty soon - Gordian Knot - and things that don't work.
Plugging parts into a breadboard and then connecting them to other parts with little press in jumper wires is relatively easy. Plug something in the wrong place and you merely have to unplug it and move it to the right place. NOT SO when you want to actually put things INSIDE things - since what goes to what INSIDE can't be seen easily - and things need to be soldered together then covered with shrink tubing.
But I'm making progress and having fun - often enough to keep going. If this idea for interactive pieces works out I'll post the HOW TO along with the software code to make things do things, along with links to sites I found useful. I'm going at things in a Modular way so - with luck - Ill end up with a Pick From Column A and Column B menu to chose from for future pieces and be able to Mix & Match fairly quickly and easily.
"Stamp Controller" Interactivity Progress
Re: "Stamp Controller" Interactive - Progress *LINK*
fgvanatta
The problem here is - if it really is a problem - this quickly turns into an electronics project instead of a woodturning project. Some folks do both, but most probably don't.
charlie belden
Sometimes it's the physical act of turning, the result a mere consequence.
Sometimes it's the turned piece, the turning merely a necessity to get it.
Sometimes the turning is merely the starting point for carving, texturing, piercing, burning, scortching, coloring, etc. I see the use of light and sound as just another set of post lathe enhancements.
What IS different about this stamp controller stuff is that, unlike the other post lathe "enhanced" pieces which still remain still/static, the results can be static / unchanging - OR - constantly changing AND reacting / adapting to what goes on around them. And the reaction(s) and their triggers can be changed completely, by changing the behavior instructions - changing a few lines of code or using a completely different set of instructions. It's the added dimension of time, that ability to change over time, that's interesting.
At the moment, this is more of an electronics project. But the objective is to use electronics as a means to an end - pieces that are not static over time - which change appearance, and/or orientation and / or sound.
And there's some interesting stuff that's been and is being developed for the unsighted - which change textures of a surface to convey ideas and literally, feelings.
I envision possibilities for turned pieces that go beyond Look But Don't Touch - that go in so many different directions/ dimensions. As is often the case, if one can make it easier for others to explore some of these areas, some will go exploring. And if they share what they discover - I think others will benefit from that sharing - and turning will expand a bit more. Like the surface of an expanding balloon, there will be more spaces for people to explore and play in.
Scott Greaves in Blackfoot ID
Hi Charlie!
I haven't chimed in before, but I wanted to tell you that I think your work on interactive pieces is exciting and intriguing! I have always thought that turnings should do more than just sit there and look pretty. That's why I have concentrated on penturning, because of the special tactile relationship between the turning and the user. I have also been making some canes, for the same reason.
But your pieces really take this concept to a new level. I really like the direction you're heading with this, and I am excited to see where you end up. I do not have time right now to look into the possibilities of these controllers myself, and am glad you are willing to share what you are finding out.
Thanks!
Scott.
