REAL MILK PAINT
All y'all cowboy hat turners out there
Steven Antonucci
Steven Antonucci
As I have recently posted a couple of 'just OK' hats, I am deciding whether or not I want to make one for myself. Ok, I decided. I do. Being from NJ, it's going to be hard to pull of the look, but I want to give it my bestest.
So, I have seen Hannes do it in a demo. I know all of the steps and jigs he uses, but I have enough sparsely used things laying around the shop. The first two I made were done on a faceplate and a set of cole jaws. The top is a wee bit thick in #2, and I think I can get it in #3.
Here is where I need some help:
1.) What measurement do you need to fit it to a head? Front to back is too big after the hat dries. left to right is probably too small. Do you average them?
2.) Has anyone tried "steaming" the hat before bending it? I broke the last one (#2) on the brim when I got too aggressive with the bend. I think it may have been too dry.
Thanks y'all
Steve
Re: All y'all cowboy hat turners out there
Dennis in Southern Oregon
Steven, I don't claim to be an expert, but I have made several successful wearable hats :) and about as many failed attempts >( . The sizing method that I use to determine the inside diameter of the hat at the hatband is to average the the length and width of the head at the fitting point and add an allowance for the shrinkage of the wood. This allowance varies from abut 1/4 inch for well-behaved woods like sweet gum to 1/2 inch for madrone. To get the the required outside diameter of the hat at the hatband add another 1/4 inch (wall thickness 1/8 inch at hatband).
For good bending, the wood needs to be green wood with lots of water and the wall thickness should be cut uniformly to about 3/32 inch. You may need to keep wetting the hat while turning to keep it from drying out. After the hat is turned, let it rest for several hours before applying much shaping pressure.
You can find articles on the web by Googling turned wooden hats. If you like I can email you a couple that I have collected. Dennis
Doug Thompson near Cleveland
Steve, along time ago I turned hats.
First to size a hat you need a measurement of your head front to back and side to side. Johannes will use a Curvex drafting ruler which is lead filled flexible that comforms to any shape, maybe some heavy wire might work too. Wrap it around your head till it feels comfy then place it on a sheet of paper mark the shape, measure side to side, front to back then adverage the two numbers. Mine is 6 X 8 so the hat size is a 7 then you add 1/2 inch to make up for the thickness of the band (1/8 inch times 2) and shrinkage (1/4 inch) when the wood drys. The measurment of the outside of the band when it's turned will be 7 1/2 for my example.
The weight of a hat needs to be 6-7 oz's when dry before the finish is applied, anything above 8 won't bend well at all... weight yours. The secret is when you think it's thin enough take another cut and the corner between the band and brim needs a gusset, square corneras won't bend. If the wood doesn't bend easy on the lathe it won't bend well in the jig... a light touch with one finger is enough to test.
Good job so far.
Texian
Guess you could measure the circumference of your head with a cloth tape measure. Divide that number by Pi and you have the diameter (if your head was round). Then add the adjustments that others mentioned for shrinkage, etc.
Pi is for measuring your stomach
Steven Antonucci
Also, how wide are the brims?
Steven Antonucci
I think mine are a little small. Need to get some bigger maple, and maybe a bigger lathe too...
I can swing 15 3/4" over the ways. What's a "regulation hat"?
S
Re: Also, how wide are the brims?
Depending on the style of hat, the brim width, measured out from the crown, typically is 3 to 4 inches. This would give a total diameter of 13.5 to 15.5 inches for a typical 7.5 inch crown diameter. You should be okay if you carefully trim the bank before mounting it.
Dennis
cliff
turned a few small ones myself and would like to try larger but can find very little info on jigs and deminsions. can someone here help with more info?
thanks, cliff
Woodhat.com is...
Johannes Michelsen's web site, the video gives you enough info to turn a hat... the 3 day class is outstanding.
Steven Antonucci
Thanks all
Steven Antonucci
Next time I post a hat, I'll be wearing it ;)
S
