Does anyone of you try to cut your own 2" or 3" H&L sanding disc from either 6" solid disc or H&L sheet? The cost per disc goes down from 30 cents per disc to about 7 cents per disc.
One of the turners claims that he made a die out of a hole saw. I tried to this with no success. I was unable to grind the edge sharp enough to cut.
If you have drill press you can use a hole saw easily. Just grind off the teeth to start. Then hold the hole saw in your press and hold a file against the edge. If you hold the file on the inside the disk will be the correct size, if on the outside they will be a bit undersized. Another way I did it was to get a piece of galvanized pipe of the required size and file the edges down to a sharp edge with a file. Then put a piece of wood on the top and hit the wood with a sledge hammer to cut out the paper. I used Industrial Abrasive Rhyno paper with good success. Now though I have given both up and buy my paper from Vince. More expensive sure but the time savings are worth it. Also his paper seems to last longer than the self cut out stuff. The I/A paper though is superior to most other papers.
I ocassionally purchase a box of roll ends from Klingspore that have the velcro type backing. Some of the rolls are 3 inches wide and some two inches wide. I found that by cutting off a piece that was square it worked just as well as the round disks. I do purchase round disks and use them often, but I find the square pieces work just as well, especially in grits of 220 or coarser. I had a student a year or so ago, who said he had been trying to cut disks for those roll stuff. He said what I showed him about the square pieces worth the class fee. I've been doing this for several years with good results.
I made some with a hole saw. I sawed a hole in a piece of wood. Then sandwiched the sand paper between that one and another piece of wood and used the hole saw in the DP to cut through the same hole and make disks. I found that sandwiching the paper kept it from bunching up. It was slow, but worked well enough.
There is an article in the articles section I think about cutting your own with the band saw. Buy a one meter square piece of paper from Industrial Abrasives and cut it up on your band saw with an old blade. Cut it in strips and then stack and cross cut the strips. The squares work well and are dramatically cheaper than disks. I suppose you could nip off the corners if you wanted to.
I use H&L from Klingspor to make my own sanding discs. I cut them square and just "fold" the corners over the mandrel. Cutting round discs is a waste of time.
Here's a pic of the tool I use to cut 2" discs. The hole saw is 2 1/8" dia and sharpened on the outside. The extra 1/8" OD results in 2" ID +/- an inconsequential amount. The handle has a bolt welded to the end that goes through the washer and fits the hole saw. There's enough extra thread for a jamb nut which is installed with an impact driver. The nut is necessary to keep the saw from unscrewing in use and the thick washer is needed to distribute the impacts across the entire rim of the saw. A 3-4 pound mini-sledge hammer and some scrap MDF or particle board does the rest. Though I haven't done it yet, other saw sizes could be used with the same tool.
