I haven't' used my cherry salad bowls for a while and they have a slight rancid odor. I use only vinegar and oil for dressing and wash with a light soapy wash.
What am I doing wrong, should do, or what would you suggest?
Are you using Olive oil? Supposedly it will go rancid. (Never ahd it go rancid on me, or maybe I never noticed.) I use it all the time on my bowls and have not had the problem. Actually, My bowls have a number of coats of SunFlower oil as a "finish". But when I eat out of them, I make the dressing in the bowl and it is often Olive oil, vinegar, and garlic. I change it up with different vinegars and ginger in place of the garlic.
Not sure, but what I would do is put some salt on the bowl and scrub it with a piece of lemon. Rinse, Wipe, let dry and apply sunflower oil. Or walnut oil. I like the sunflower oil because it has little or no odor and does not go rancid. It does not dry though. I think walnut oil does dry. Has a slight but pleasant odor.
I could maybe help a little better if I knew what finish they had on them to start with. But, since I don't, I will say this.
If you wash them in hot soapy water, dry, and then let them finish air drying, and they still smell rancid, it might take some salt to fix the problem.
I would do the wash job, then dump in about a table spoon of salt, and use a half of a fresh lemon to scrub the interior, with enough warm water to make the salt into a light paste.
The salt and lemon should take care of the problem.
Don't just scrub it, like you were trying to sand it, but do it lightly.
Vegetable oils will go rancid. If you want to use oil on the bowl as a rehab, use Mahoney's Walnut Oil. I don't put oil on my own bowls for use. And I wash them in hot soapy water when we've finished using them... I don't want to leave the oil residue in the bowl... sometimes you can't get it all out, but that's just the nature of the beast.
Olive oil will go rancid. Supposedly, the only vegetable oil that doesn't is Walnut oil, but I suspect even it will go rancid in time. Even so, I do use Walnut oil, but always in combination with shellac.
I do use and have used Walnut oil for years. I have had the oil get a little rancid in the storage container. I have never had a problem on a finished product. I had never thought of it but possibly the summer shop temp of 120 could have something to do with that
