THE WOODRAT IS BACK!
threaded box
threaded box
threaded box
Here is my latest threaded box. Since I'm playing with epoxy threads I'm more interested in how that works than the overall box, consequently the design of the box is secondary and I just finished it because it will make a nice gift for someone.
This is West Systems 107 epoxy with the 207 hardener. It cuts nice and clean. The epoxy is clear if polished but that's hard to do on threads. It will pick up the color of the wood if you leave wood behind it such as in the lid.
These are 16TPI threads from my homemade chaser.
Re: threaded box
Barb Siddiqui
Re: threaded box
Barb Siddiqui
The epoxy is mounted above the wood? How did you frame it to pour?
Re: threaded box
Re: threaded box
Greg Haugen
I like it a lot. That's interesting with the epoxy.
Well Done.
Greg H.
Re: threaded box
Re: threaded box
Stuart Johnson
John, please explain, better yet show, how you are using the epoxy to great the material for the threads.
Re: threaded box
Steven Antonucci
Sharp thread...box... ehhh?
steven antonucci
I get the fact that it's a prototype, but now you have that lumpy box sitting around your shop...
Now what? ;)
S
Re: threaded box
Re: threaded box
Barb I do it 2 ways. One is to simply cut a groove in the wood and pour the epoxy in. This is what I did on this box. The other way is to build up the outside with masking tape and put a piece of PVC pipe on the inside so I don't waste so much epoxy. Then I just turn away the PVC while I hollow the box and cut away the tape and excess epoxy when I shape it for the threads.
I do turn a very shallow groove before pouring the epoxy so that there is more than just an endgrain to epoxy bond. I don't know yet how well epoxy will hold up to wood movement. I did run a test to see which epoxy and hardener that I have is the most flexible to try and get around this problem.
Re: threaded box
Re: threaded box
I'm going to start another one this weekend. I'll shoot the steps. I like the epoxy because it lets you add threads to woods that would not accept the cutters without tearing the threads.
Re: threaded box
Re: Sharp thread...box... ehhh?
One of these days I'll learn to control the gouge and not get those darn lumps. :) Someone will probably get this in their stocking for Christmas.
Re: threaded box
Re: threaded box
Terry Scott
Hi John
Great idea never having cut a thread I appreciate/ admire your skill
My suggestion would be to color the resin black this would help to take away the plastic look
At the moment it looks a bit like you got a bottle top and lid and added to your box
I like the texture and the beads this all helps to make a top line product although the beads need to be a bit more uniform the top one seems to throw the shape a bit as it is larger than the one under it
The contrast between black and the interior wood brings that sense of mystery i feel is important when opening.Its saying keep your valuables in here they will be safe
Just from were I sit others may disagree
Cheers
Re: threaded box
Re: threaded box
Terry I agree about the rings. However this wood was crappy and I had to reduce the size of the ring just under the lid to get rid of the wood that flaked away. I couldn't reduce the size of the ring above the joint because the epoxy would show through. I was stuck so I left it.
I do dye the epoxy black but did 2 boxes with clear epoxy to see how it looks. The black epoxy would look much better with the black outside. The plastic look is the one downside of using the resin. I prefer all wood but just can't afford the pricey woods that you chase threads in.
I have another one started. The beads are better. I still haven't decided on the texture yet.
Re: threaded box
Leo Cuellar
Re: threaded box
Leo Cuellar
I like the texture, makes me think of leather. What speed do you chase the threads at?
