REAL MILK PAINT
vacuum systems for lathes
woodenleg
i am getting the courage to start building a vacuum system for my lathe. I have seen plans making the "tank" out of PVC to help keep the vacuum level but now I can't find it. The system is for a Delta Midi. Thanks for your help. Dave
Re: vacuum systems for lathes
Terry Gerros
You might check out JT Turning Tools, www.jtturningtools.com They have all the things you would need to set up a vacuum system on your lathe.
Terry
Try Joe Woodworker site. Huge amount of Info on Vacuum. Everything from info to actual systems and parts of systems.
Re: vacuum system side note
For turning, you have no need for the "tank" that you mentioned. That item is used in vacuum bag (veneer etc.) rigs to allow the pump to cycle on and off over a long period while maintaining the vacuum pressure.
For turning, you're using vacuum to hold the item to trim off the bottom/base or for holding unchuckable items like a platter for final finishing, etc. It's not something that you leave running for a long time like the veneer guys. I know there are those turners who use a tank for a safety device in the event of a loss of power, but in that situation the lathe will have also stopped by the time the vacuum drops to the release point.
Look for a vacuum pump that pulls at least 4 cfm (6 is better). If you do small turnings (2-4" range) you'll want a pump that can pull a higher vacuum (mid to upper 20's in inches of Hg), but larger pieces, depending, of course on their weight, will need less. I've safely held 20+" platters with less that 10" of vacuum, because the bell/chuck used was much larger in diameter.
Bill Howatt
Correct, there is no need for a vacuum tank.
I have held small bowls on my approx 4" dia homemade drum chuck with 10" of vacuum but this is where I get a little nervous. Without turning tool pressure being applied the bowl will stay on the chuck with less than 5" of Hg.
The important thing for a power failure is that you have a battery operated emergency light that will allow you to see the bowl as the lathe slows (so you can catch it) unless you only turn in the daytime with lots of natural light.
Bill
Vacuum - little long
Not to pick on Bill, but it's important to understand the concept.
At sea level, air is placing about 15 lbs. per square inch on every surface. We don't feel this because the "pressure" inside our bodies is the same. However, once you lower the internal pressure, the air begins to exert a positive pressure from the outside that is quatified by how much the internal pressure is reduced. Take internal pressure to "0" which translates to 30" of mercury (Hg.), and the air exerts a pressure of 15 lbs. per square inch. 20" of Hg gives 10 PSI, 10" gives 5 P.S.I.
To figure how much pressure is being exerted on your workpiece you find the area of the vacuum "bell" chuck in use and multiply that by the P.S.I. rating of the vacuum level.
A 4" chuck has an area of its circle (pie x r2) of 12.56 sq. in. [2x2x3.14]. If I have 20" of Hg. on my vacuum gauge, I have 10 P.S.I. being exerted on 12.56 sq. in. for 125.6 pounds of effective pressure holding my workpiece on the chuck; enough for secure holding. If however, my chuck is only 2" in diameter, the area of its circle is now only 3.14 sq. inches so at the same 20" vacuum level I've only got 31.4 pounds to hold the small piece on; not nearly enough to work with.
Conversely, were I using an 8" chuck to hold my hypothetical 20" platter, at 20" of Hg. vacuum I'd be putting more than 500lbs of pressure on my platter which could, if it were thin enough, implode or break my piece. It's therefore very important to have a bleeder valve in a lathe vacuum system to allow the amount of vacuum to be regulated to fit the job being done.
hth
