Well I have had a hold up as my supplier of the Rust and Verdigris has turned out to be a proper twat I ordered a litre of each in 500ml containers 2 weeks ago and called today and asked if there was a problem
Yes we dont have any 500ml only 100ml
as you are the only one that seems to want it in 500ml we will have to order it in ad we only place an order every 6 months
I dont often loose my Rag but they got both barrels
Anyway found another supplier and its on its way plus cheaper
I have a gallery owner calling around tomorrow night and I was supposed to have the 4 platters ready for her to look at
>.... Happens
So decided to start this last night
I just invented this system of holding a hollow form so I can carve it .Hot melt glued an axle on one end and a faceplate in the neck .I can know sit in my office chair without the risk of holding it between my legs and the thing jumping onto the floor
The pro mount is my friend every opportunity I can i place work on it to work on its so versatile.
All my vacuum parts fit on it as well
Just set up this air conditioning fan what a difference has plenty of suck
My wife is moaning though as the outlet is pointing at the washing line
The computer fan I had hanging from the light was ok but the blades dont like a winged vessel being stuck into them much
Necessity IS A Mother. And you're probably wondering why you didn't make one of these two years ago ; )
Add INVENTOR to your resume'. And you're "only" a part time turner? (When does this guy sleep?)
Wonder if your suppliers of Witches Brew are anticipating an order for Eye of Newt and Toe of Frog?
Your creativity, skill and productivity are impressive - but it's your willingness to take the time and energy to share what you've learned that I really appreciate. Thanks.
