goblets
richard fulner
have just finished a pair of goblets for my cousins weddingwould like some sugestions on what type of finishes i could use
thank you
goblets
richard fulner
thank you
Re: goblets
Jorge Casta�eda
Richard, I did that recently and finished to goblet with lacquer, a very soft gloss.
A friend of mine makes lots of goblets and she finishes hers with CA glue and gets a very high gloss finish, just like many pen turners do. I don't know how they do it.
Hope this helps
Jorge
Re: goblets
Bill Tucker
Congratulations on the goblets - they're fun to do. If there will ever actually be liquid inside them, it would be a good idea to put one or two coats of medium ca glue on the inside up to the lip. I usually start with a shellac based sanding sealer all over, ca on the inside, 3 coats of walnut oil with a day between each coat on the outside, followed by buffed wax. Post a picture and brag a bit!
Re: goblets
Jeff Rich
I used to use a Salad Bowl for the inside bowl, but I have switched to no finish or a beeswax coating.
I have several friends that use theirs and they sanded the finish on the inside to bare wood, it then develops a patina from whatever is put into it.
I do use BLO on the outside with a beeswax for some shine and protection.
I have seen some people use bar top epoxy or spray on 3 part finishes...
Could have asked Russ Fairfield
jimmy edwards
But he apparently bailed out of the forum. See above post by him.
