Tung oil
Tung oil
Aage Rendalen
Tung oil
Aage Rendalen
The local big boxes have stopped selling gallon containers of tung oil. Woodcraft has it but it costs more than $50 a gallon. Two questions:
1. What could justify such a price? What kind of miracles does it accomplish?
2. Who still sells the $20 a gallon tung oil?
Re: Tung oil
Walt Bennett
Re: Tung oil
Walt Bennett
Guarantee that if you're paying $20 a gallon, there's probably only a pint or so of actual tung oil in the container. If you what pure tung oil, it'll cost around $46 a gallon plus shipping - but that's the stuff that takes a couple weeks to completely cure. Waterlox is tung oil with a lot of accelerator so it dries in less than an hour. I use a fifty-fifty mix of original Waterlox with pure tung oil (try The Real Milk Paint Company for one place to get it) to get some working time and still have things cure in a few of hours. Mixing it also lightens the color quite a bit.
Re: Tung oil
Aage Rendalen
Makes sense
Aage Rendalen
Thanks for the info.
Re: Tung oil
Re: Makes sense
Allen Neighbors
I'll check with my source, here in town, and find out what it costs. I get 100% pure tung oil from him, but I've forgotten how much it cost me. I'll get back to you.
Re: Tung oil
Re: Makes sense
Barry L Elder
If you have purchased a product for $20 a gallon, then it is more than likely a Tung Oil Finish. 100% pure tung oil cost is more like $20 for a pint. When I first started researching tung oil (Google is your friend) I went through pages and pages of info. Pure tung oil carries the recommendation of a 50/50 minimum mix with mineral spirits or whatever would be your choice and using very light coats to enable faster curing. Many of the more experienced turners' comments suggested that pure tung oil caused less color change in the wood than any other oil finish. There are not too many sources for 100% pure tung oil. If you purchase it in a large chain store, it is probably not 100% pure tung oil. It's just not that popular. On my few turnings, if I even think it's possible that the piece will be used for food, then I apply at least six coats of tung oil before considering the final coats of whatever finish I apply. Then when asked, I can say that it is food-safe and that the shiny surface will go away!
