Re: Bowl hollowing problem
GaryG in MD
Starry,
You have received good advice above. Here's my "take" on it...
I rough the outside first between centers and add a tenon for chucking.
Then I reverse into the chuck for hollowing. No matter how carefully you cut the tenon, the chuck jaws will crush it unevenly and lead to a slightly crooked mount. One way to help alleviate this is to bring up the tail center into the hole made by the spur center or steb center before you tighten the chuck jaws. That helps get as straight a mount as you can possibly get.
Some people even do some of the hollowing with the live tail center in place and work around it as long as possible before removing it and the big nub. I've done that in the past, but I find it frustrating and quit, just getting the most out of the centering before going on.
Even so, you'll probably find the need to slightly adjust the shape of the outside before (and possibly during) hollowing. Wood that you think is "dry" seldom is. I made a bowl out of a piece of cherry I had drying for years, and had to wait a day or two between turning the outside and the inside. The outside went oval, and I just left it that way -- with an oval outside and circular inside -- gives it some "interest" -- call it a "design feature" if asked! ;-)
Just remember the rule -- as Fred said -- once you have the rim thin, NEVER GO BACK (DAMHIK!).
...Gary
