How do I Glue Magnets?
Doug Wolf
I bought some rare earth magnets to hold a lid on a box. I drilled 1/4" holes in the rim of the lid and the box and now I can't find any type of glue that will hold them in the holes. They seem fine until I pull the lid off 5 or 6 times, then they pull out of the holes.
I tried "E-6000" (like a silicone glue), 5 minute epoxy, Thin CA glue.
If anybody has had better luck, I would like to know what to use.
Thanks in advance.
Re: How do I Glue Magnets?
Barbara Gill
What about gluing plugs in each hole to trap the magnets? Hopefully the glue will hold the wood.
Bill Youngblood
Doug - several years ago I used either medium or thick CA glue to hold magnets for doors on a cabinet. They are still holding. Might be worth a try. Good luck.
Dave Belser
Rough up the nickle surface slightly with fine grit sandpaper (400 or so) and use super glue. I've had good success with this technique. Other tips - use tighter fit on the holes. I sometimes use thin glue in the hole first and let it dry. The magnets can be handled with tape or another magnet and a piece of plastic between to prevent the second magnet from being glued on also.
Hope that helps.
- Dave
I watched Sharon Daughty do her boxes. She used 1/8" magnets, counter sunk them below the surface and filled in the gap with sawdust. She used CA glue. I think it was thin but her magnets fit really snug. She also used the CA to set the sawdust.
john lopez
shoe goop
