pin chuck
richie c
Saw a guy on youtube use a pin chuck for some turning. Wondering what your thoughts are on this simple jam chuck. Do many of you use one,for any special applications ,is it safe,would you buy one or use something else?
pin chuck
richie c
Re: pin chuck
Don Evans
Hi
I've used lots of them over the years. Even had some special ones made way back that could be locked into my scroll chucks. They were may with an end on them like the screw that can be purchased for some checks.
I thinks they were good for their time period but their are problems with them due to their design and these problems come mostly with the softer woods. Hard exotics work best but they are prone to the wood coming loose during roughing out because of the vibration but once smoothed they work ok. I would not consider them for anything other than small turnings like bottle stopper etc.
There are better ways now like for stoppers and anything that you used a pin type for and that is Ruth Niles mandrel. I just purchased one with the stub drill bit for two reasons. First it is morse taper (fits #2 morse) but most important it is used with a drawbar so no coming loose during vibration problems.
For larger stuff I know some that use larger pin types like 1" diameter but I wouldn't consider that, for that large it is time for a scroll chuck to hold large stuff for safety if for no other reason.
Don
Re: pin chuck
Russ Fairfield
Pin chucks are popular among pen turners. They work quite well inside of a brass tube.
Re: pin chuck *LINK*
Don Evans
Here is Ruths link, you can look and judge yourself...
Re: pin chuck
Don Evans
Russ, that's a great tip.... never gave a thought to enforcing the hole although I have done it with CA and waited till next day so it is good and dry before inserting the chuck.
Don
Re: pin chuck
Ron McKinley
I use a pin chuck for bottle stoppers but they are problematic in soft woods. You can overcome that by using the tailstock until it's roughed out and you're ready to work on the ends...Ron
Re: pin chuck
Dick Coers
I use a pin chuck to turn my bird house ornaments. I turned the chuck from a piece of padauk on the wood lathe. I turned a 1/2" tenon on one end and use a Beal collet chuck to hold that. Then I turned the body of the pin chuck so it would be concentric with the tenon. Works great, makes high production on the body of the house. Use a roofing nail (minus head of course) for the pin, right at 1/8".
nm;thanks for the info
richie c
