Do you REALLY use CA to stop bleeding?
Carole Valentine
Had a gash from a freshly honed shew this morning and could not seem to stop the bleeding...soaked right through everything...really irritating since I wanted to get on with the job at hand. Thought about the CA but chickened out...couldn't imagine the smoke and burning pain when it started reacting with the blood! Do some of you actually use that stuff on cuts? Is there a big difference between the medical grade and the stuff we use? Doesn't it hurt? Oh and one thing about a really sharp skew...it's so painless that you have no idea you have cut yourself until the blood starts running from your hand down your arm and splattering on your toes! LOL None on the wood, thank goodness.
Re: Do you REALLY use CA to stop bleeding?
The main advantage of applying...
bob elliott
...the medical grade stuff in surgery is that the patient is asleep and it's used as a skin closure. Just dwell on that one for a couple of seconds...
Re: The main advantage of applying...
Carole Valentine
LOL! That probably means that if the patient happened to wake up in the middle of the CA application, he/she would come up swinging and the surgeon/nurse may well end up with a black eye! Guess I will stick to pressure for things like that.
Ken Oakley-Sunny St. Cloud, Fla
My wife had open heart surgery in January and they used surgical glue to close all incisions. I am told it is the same as CA glue. I have seen guys at my last job use it to stop bleeding from cuts they received working. It works.
Yes
Ron Sardo
There a big difference between the medical grade and the stuff we use.
Liquid Band Aid is "over the counter" medical grade stuff.
I do know people who play guitars that use the regular stuff whenever they cut a finger on their left hand, they swear by it. I wouldn't use it.
Barbara Gill
I have used it to keep a cut closed after the bleeding has stopped. I never tried using it to stop the bleeding.
There is a product called Liquid Bandaid (I think). You squeeze some on a sponge like applicator and seal the injury. I am pretty sure this is CA glue. I have read somewhere that the medical grade CA does not produce the chemical heat that some of the CA glue we use does.
I rarely get excessive heat and smoke with Starbond CA.
I have never done it myself, but my girl friend used mine to glue a nail, ONCE. She actually got tired of waiting and hit it with the accelerant. It was over pretty quickly, but she had tears in her eyes and she never asked to use it again.
I have a friend that is a professional cabinet maker and he has used it so much for closing small wounds that I think he has forgotten it can be used on wood.
And the medical stuff does not produce the heat. Maybe I should get some of that. Come to think of it, I have put it on broken finger nails and I don't recall the heat but I used the medium.
There is a big difference...
Steve Russell
Hello,
The common industrial types of cyanoacrylates we use in woodturning are not the same formulas used in the medical profession. Typical industrial based cyanoacrylates are usually ethyl, or methyl based esters and can produce significant heat during polymerisation.
Medical grade cyanoacrylates by contrast, are typically n-butyl-ester, isobutyl ester, or octyl ester based and are specially prepared to cure with as little heat during polymerisation as possible. Excessive heat or rapid cure during polymerisation can lead to tissue necrosis - not good!
Inside the body, medical grade cyanoacrylates are bacteriostatic, are painless to apply when used as directed and eventually break down harmlessly in the tissue. Once cured, the cyanoacrylate is essentially inert. N-Butyl ester based surgical cyanoacrylates are rigid when dry, but provide a strong bond. Octyl products offer increased flexibility when dried, but reduced bond strength. Each has its preferred uses.
Better Woodturning and Finishing Through Chemistry...
Steve Russell
Eurowood Werks Studio
The Woodlands, Texas
Grant Wilkinson
Since I don't have a source of the medical grade stuff, I used plain old CA. It does sting, but it seals the cut quickly and I can get back to the job at hand. I have the liquid bandaid, too, but it doesn't seem to heal as quickly. It's good to protect cuts after they've stopped bleeding though. Good for broken blisters, too. It stings something fierce, too.
Steve Kubien
Steve Kubien
I once used OUR cyanoacrylate to close a cut. That hurt like hell (no, I will type "h*ll" in this case. Readers need the whole effect!). I won't do that again unless I absolutley need to.
I have also used the over-the-counter spray stuff frequently. It stings a fair bit but it works. My most frequent use for it is in the martial arts. I spray the balls of my feet and in the joints of my toes if I am going to be training on a hardwood floor. It REALLY helps cut down on blister formation because I can slide on the floor even if I am sweating.
Yes.  It burns, but it works and it's fast.
Greg Haugen
Re: Yes.  It burns, but it works and it's fast.
Emmett Manley, Lakeland, TN
Yes, I use CA glue to close cuts, but not to stop bleeding. Blood, being mainly water, provides the hydroxyl ions needed to accelerate the polymerization, which generates considerable heat when "industrial" CA glue cures rapidly. Also, don't use an accelerator when you apply CA to your skin or you will certainly get a burn.
There is no concern about bacteria being in CA glue -- or systemic toxicity because of the small amount applied, and the fact that it is not absorbed.
Applying CA glue to the skin is much safer than inhaling the vaporized CA or getting it in your eyes.
Dick Hines
Dick Hines
Carole ther is product out there called New Skin. Ruth used it no me ONCE. I thought she had set my hand one fire. I had rather bleed.
I just use a paper towel
to get the bleeding stoped. Then dump some peroxide on the cut. I have been to more than one club meeting with my hand wraped in a paper towel. Right Barbara?
Barbara Gill
Yep
A piece of masking tape works well to close a cut also.
Bill Grumbine (Kutztown PA)
Carole, I guess I do it a little differently than most of the others here who have used CA to close a cut. I don't squirt the glue into the cut, I close the cut and get the bleeding as controlled as I can, and then squirt the glue over the cut. It doesn't hurt nearly as bad, and works pretty well.
I bought some of that liquid bandage stuff at the drugstore once. The bottle proclaimed, "sterile until opened". I figured that wasn't any better than the stuff I use in the shop. So now I use my shop glue, and I have had no trouble with infection.
Barry L Elder
Nu-Skin has been around for a long time. Back when I used to bowl in tournaments, sometimes the callous on my thumb would split open. After applying Nu-Skin, there would be various howls and groans but it worked and I could get back to taking money!
Steve Kubien
That's the stuff I use.
Steve Kubien
Steven Antonucci
Direct pressure, duck tape and a paper towel...
Steven Antonucci
Tried it without the paper towel once, and the glue in duck tape burns worse. Wrap the cut in a paper towel and then apply pressure with the tape. Usually stops pretty quickly... and you can get right back to turning without marking up your pieces!
steve
CA glued myself once, bu it just leave hard little red lumps everywhere
Carole Valentine
Seems some are brave and some of us aren't! Afraid I'm in the later category. Pressure and ice finally worked, then I opened it up again in the shower and started all over! The moral of this story is: NEVER stick you skew in the front row of the tool rack point up! I usually don't...it's always in the back where I don't reach over it for anything...don't know what got into me this morning. Of course there are those who say tools should never be in the rack business end up anyway, but I don't like it like that. I can be stupidly stubborn sometimes! LOL
Barbara Gill
I store my tools sharp ends up. The only time I cut myself was when my hand slipped when I pulled a gouge out .
fgvanatta
Me, too, Barbara. It's hard to tell a gouge from a skew just by looking at the end of the handle.
Sharp end first
I keep all tools on shelves with the sharp ends towards me. I never have to mark the ends of the handles and memorize which is which and I never guess wrong and pick up the wrong tool.
Marking the ends won't work anyway for tool handles with collets where the working ends are switched on occasion. For example I have some large Monster Tool handles shared by several Thompson gouges.
http://monster-lathe-tools.com/cart.php?target=product&product_id=258&category_id=65
Keeping tools with the sharp ends away might work for me if I only used ten tools but I like to keep more, some duplicates (to delay stopping to sharpen).
I have not cut myself. Of course, I don't reach for a tool without looking. And the tools are flat on shallow shelves so I never have to reach over one to get one in back. Look, locate, reach, pick, pull. Standing tools in a multi-row vertical rack with the sharp ends up seems unwise.
BTW, another thing which I find helps immensely while working is a tool tray that fits on the lathe ways. There I keep just the very few tools I am using for the current work. The tray keeps the tools handy and prevents them from rolling off the lathe. I made this in just a few minutes and use it every time I'm at the lathe. I've posted this before but some may not have seen it.
Sorry, no picture of the tool shelves themselves except a glimpse of one at the top edge of the lower photo.
Don Thur
Recently I caught my index finger between a spinning burl and the tool rest which cut/ripped a 1" gash that I knew required stitches but I needed to get the bleeding stopped so I could head to Emerg. I thought of using the CA but thankfully didn't because the surgeon told me that if I had of coated the cut, they would have to 'scrape' the glue off before patching me up. That would have been an ordeal that I sure would not be happy with.
Dick Hines
Dick Hines
I have enough trouble remembering what day it is . There is no way I could store my tools with the sharp ends down. I would spend most of my time looking for the tool I wanted to use.
Re: Yes
Chuck Hans
This may sound like it hurts but it doesn't at all, Black Pepper stops bleeding immediately with no pain.
Chuck
