Brown Malle burl
Brown Malle burl
Brown Malle burl
Terry Scott
Ive had this burl kicking around for a while realizing that it was going to be as hard as the knobs I had to be in the mood so to speak
Because this cost me an arm and a leg I didn't want to ruin it
I manged to save 2 bowls out of the inside but a bark intrusion /rot ran through them making them useless .These I will keep for smaller items hopefully enough inserts and pens that I will at least get the cost of the burl back
I used my Kelton bowl saver followed by my hollowers as my bowl gouges just lost their edge very quickly .If I hadnt saved the bowls I think id still be there beavering away this was hard work
I also had to use ear muffs as the noise was horrendous
The rim has been carved and then verdigris and iron applied to give an old worn look
Sits on 3 carved feet
Comment always welcome
Re: Brown Malle burl
Wonderful Piece
jake Niedling
Terry - It may have been a bugger to turn, but the results are great. I always enjoy seeing what you have done. That technique you used around the edge works well with this burl. By the way what size is this piece. Thanks for sharing.
Jake
Greg Haugen
Terry, that's beautiful! Everything is simply wonderful about this piece. Well Done.
Thank goodness for the Kelton hollowing tools. Love them. Kel and Alby did an excellent job.
Greg
Steve Kubien
Steve Kubien
I gotta get me some verdigris. I love the effect. Terry, you have got more courage than I for "painting" this lovely piece of burl. No way I would have had the guts to do. You made the right decision as this piece is fantastic. Very well done.
Re: Wonderful Piece
Terry Scott
size is 18inches across
I have a number of other burls natural edge that I have wet turned ,I will be dong something similar me thinks
Everyone that has seen this so far really likes the contrast
Next month I will be attending an art show my first so we shall see how a normal burl competes against this
I will have this about 20% higher in price so we shall see
Sean Troy
That came out beautiful ! Well done all the way around on a very difficult wood.
