MOISTURE METER
MOISTURE METER
MOISTURE METER
woodspinner
A friend and I are setting up a large drying room and need a good moisture meter. We want a pin type because we need to test several types of wood. Wood ranges from Mesquite to Ironwood. We can not afford a super pricy unit but we do want a quality unit.
Any ideas apreciated.
Re: MOISTURE METER
Re: MOISTURE METER
Matt Overton
I am very happy with my Delmhorst (sp). Not cheap (around $200), but accurate and has 50 species built in memory.
Re: MOISTURE METER
Re: MOISTURE METER
woodspinner
Thabks Mat
Re: MOISTURE METER
Re: MOISTURE METER
Check out Electrophysics (Canadian company).
I've had and used one of their pinless meters for 10 years. Very accurate and reliable. I have a CT-100 (about $225) which quickly adjusts for a wide range of hard and soft woods.
Note that if you're drying turnings, using soap-soaking (detergent) or alcohol will render your meter worthless because the chemistry in the wood changes and throws the sensors in the meters way off.
Re: MOISTURE METER
Re: MOISTURE METER
John Scheideman
I like my Ligno. The price is right but it doesn't include many exotics so you may not want to get it.
John
