Abuse of my body is starting to catch up. I went to turn some wooden pegs for a flag pole, finished one (30 min) went to start the next one and my wooden leg is telling me to sit down. My question has anyone set up a lathe to use in the sitting position? If so how did you do it? Is there anything I need to remember ?
There have been several articles written in various turning magazines about turning while sitting.
One option is the Oneway Sit Down lathe which is specifically designed for this change in turning style. I have seen and tried the machine, and it is a pretty slick innovation. Have a look at the link below to see for yourself....
Our club (San Diego Woodturners) have been working with the Wounded Warriors program for the Mililtary Vets. One of our club members has worked on a Jet Mini lathe to allow it to lower into position for anyone sitting or in a wheel chair. They will be having an event this week and I will find out how well it works. Good luck.
When I had my knee replaced I sat on a drafting chair. The lathe I was starting with was rather low to the benchtop. I would say set up a lower stand get a taller chair or stool. If your head stock can slide to the end of the bed you should do allright.
Some guys from our club set up another members lathe and stand so he could work sitting down so I think this is not uncommon.
Dave, I have had a number of students that turn sitting down. But not from a wheel chair. That would be a more difficult proposition. I have seen that the tilting lathes like Oneways didnt work very well. OK, as a last resort but has significant obstacles. Mostly maneuverability and gravity is working against you. The best set up I saw was using a stool. Better yet if the floor permits a stool with casters. Shavings will limit the casters ability to roll, but is some help rather then getting up and lifting the stool every time you change position. AND, you have to change your body position often while you turn. Get the lathe the right height for the height of the stool, or vise-versa so you can cut comfortably on the center line.
No one mentioned the article in the latest issue of American Woodturner. It is about Jim Proffitt who turns from a wheelchair. The article was written by Dennis DeVendra who is a blind woodturner. You can contact Dennis through thelink below. He can probably put you in touch with Jim.
That you would want a stool that moves, similar to what Lyle was discussing, but I would think the customers would give you a fit.
I don't know how much you want to sink into this, but how about a large version of a swivel like they have on some of the boring bars? Some sort of arm that the seat would mount on that could swing left to right? A low tech version might be a seat on rollers on a rail with a tripod at each end so you could roll left to right maybe two feet? The rail could be curved. Or, if you had the pivot thing you could have two of them so that you could move left to right and in and out.
An even dumber Idea I had was to use one of those canes that has a little folding seat at the top. A seat on a stick. Strap it to your butt and turn yourself into a human tripod. So you could sit/lean on it and take some weight off your wooden leg and yet stand up and move when you need to.
Part of the problem is knowing what you want to turn and how big that might be. Spindles would require mostly left to right movement. Bowls might require more three dimensional access. Once you figure out the seat, adjusting the height of the seat/lathe would be relatively simple.
I'm thinking talk to the people that make the Monster hollowing system. They make you an arm with several bearings. You bolt it to a pipe column. Add a seat with up and down adjustment like and office chair and you could live there.
Jim did a demo at the Richmond Symposium a couple years ago. It was a good demo, Jim is a funny guy and a very acomplished turner.
Turning while seated is a different experince. It is all arms, hands and upper body movement. Going from a standing woodturner using lower body movement to a sitting woodturner will require developing different techniques.
Your solution my be a hybred approach. Stand for turning and sit for sanding and finishing. Have a chair close by that you can use to extend your shop time.
When I was demonstrating at the Craft Supplies UK show in 2001, I met a young fellow who was wheel chair bound and an excellent turner. I can't remember his name at the time, but here is a photo of him on his stool with the sliding seat:
I turn most of the time sitting down, now. At my OW 1640, I have a tall stool with 4" swiveling casters, and it works pretty good... just have to jump up everyonce in a while and sweep the shavings out of the way.
When I turn at Little Vic, my stool is stationary, and Vic is on a rolling platform (I take it with me when we travel). It's really easy to unlock the front wheel caster, and roll the lathe where I want it, side to side or back and forth... when I want to change positions.
I prefer the Little Vic's rolling platform, to the stationary 1640... It really does work well.
I have the Oneway 1236 SD and it is a very good lathe and it adjusts easily from upright to sit down. The advantage of the sit down position (besides the obvious) is that you can get your legs underneath your work since the bed pivots. One downside is that it is just a 12" swing so big bowls/platters are out of the question. One advantage is that the bed is out of the way when hollowing. Have used it both ways, but I bought it knowing I have 2 bad ankles, one very bad knee and now a hip that is bothering me. Too much football and snow skiing in my youth.
Didn't read every post so maybe this was covered already --- I rarely turn for more than about fifteen minutes at a time. Often less. Then sit in a nearby comfortable lawn chair, sip some coffee and pet my shop cat, for two or three minutes. And back to the lathe for another 10-15 minutes. And repeat. And repeat. When Missy (the cat) hears "Ok back to work" she knows to hop off my lap and go be somewhere else for about 10 minutes until the next break. Some of this procedure is due to "artistic" limitations (for lack of a better explanation, what needs to happen to this piece next?), but mostly due to physical limitations. Whatever is hurting will stop in a couple minutes and work can resume. So I'm slow but get to keep doing what I like.
Guess the point is that one is not required to stand at the lathe for hours, or half hours, or even quarter hours to make great looking turnings. A little bit at a time can still get you there.
Wow!! Thanks everybody, I will try the rolling stool, since the lathe is also used by my wife. I will let you know how it turns out.
I turn many spindle like items ( wooden alignment guides for putting tractors and big trucks back together, belaying pins for sailing boats ), some small bowls.
I am in the hospital now and had my knee replaced today at 1:00 pm. My plan is to use a tall drafting stool. and keep the broom handy. I turn on a Oneway 2436 so it is me that has to move, not the lathe. I am in hopes of turning within 3 weeks. My lathe is not at my home so I have to drive to my shop.
Best of luck on your recovery. Probably the meds but I feel great.
