Nothing holds up anymore
I purchased a $6000 central heat and air unit a year a 3 months ago. The compressor died today. The unit is out of warranty but the compressor may be in warranty. It's 84 in my house right now. They'll let me know tomorrow what it's going to cost.
I bought a Vizio TV. It was a little over a year old and died. Vizio said they would give me a complimentary repair. A $500 TV should last 10 years or more.
Our router to the computer went out a few weeks ago. It was 3 years old. I thought it was a pretty good one.
I can't tell you how many card readers I've gone through in the last 5 years. I've bought expensive ones and cheap ones. It doesn't seem to matter.
I guess I'm just ranting because it's hot as hell and I'm tired and won't be able to go to sleep until midnight. It will take that long for the house to cool off. Hope Jamie's house is airconditioned. :)
Re: Nothing holds up anymore
Carole Valentine
It's called planned obsolescence and it is infuriating! BTDT!
Bob Lemon
John, get a second opinion. The compressor is the most reliable part of the A/C. It is also the first thing a service man will declare dead. On my own A/C I have replaced everything at least once, EXCEPT the compressor. It is over 47 years old and still running. I was in the refrigeration/ A/C field like forever. I started formal training in '54.
Bob
Steven Antonucci
And they don't cut brake rotors any more...
Steven Antonucci
Minivan with 25K mile needs all new shoes... can't cut the rotors. Tech's say it's the price of performance, I say it's something else...
20 years ago, you did get a life expectancy out of the things you bought. However, the manufacturer soon realized they could blame it on "power consumption", "advanced compounds", and other nonsense...
I am with you, John...expect my AC was on last night, and I slept OK.
Steve
Re: And they don't cut brake rotors any more...
Matt Overton
I agree. My favorite was when the pump went on my pressure washer, the replacement seal kit cost $263 dollars. A new pump complete cost.... $263! John, I feel your pain. My house is 85 deg. and the air works great. My wife gets cold if it is below 80, so I suffer.
I thought every compressor came with a 5 year warranty and some have a 10 year one. Some are parts and some are parts and labor. Check this out Carefully.
My AC is out also. Sunday was hot as blazes and the house went to 80 degrees and It finally sunk in that I had a problem. I called a service man I know that does side work and he came and put some refrigerant in it. (In the back of my mind I was wondering why now and what went wrong. Monday, it was even hotter and i came in and the house was 80 again. Called him back and he did a little investigation and found the leak on the accumulator. He is getting a replacement today and will be back to replace it later. But, my unit is 14 years old. Still don't like the fact ht they made the parts out of material that rusted out, but 14 years is better than 14 months.
I have a fan blowing on me right now that is probably a collectable. A Robbins Myers and it must be 60 or 70 years old. Working exactly as it should. Of course, you could stick your entire head through the blade "guard", but it sure feels good until you do. I doubt any fan made today will last that long.
Dick Hines
Dick Hines
Matt you need to buy your wife a nice warm coat.
Steve I'd get a second opinion on that. I think only the cheap aftermarket rotors can't be turned but I could be wrong.
Barry They are going to call me this morning. He says the compressor probably has a 5 year warranty. I called them about 6 months ago and had them come out and listen. It didn't sound right to me. It sounded like one of those cheap HF compressors and is way noisier than I thought it should be. The guy said it does seem noisy but some of them do, which I thought was a load of crap. Mostly I wanted them to come out so that when I did have a problem I had the grounds to say, see I told you so. Now I was right so we'll see what happens. It was 84 when I got up this morning. I could hardly get my shirt on because of all the sweat. I looked in the mirror and looked just like one of those hard body sweaty guys you see in the commercials. And if you believe that :)
Dinyar Chavda
John:
If you can settle your problem through the warranty, then fine. If not, one approach that I found very useful was posting my HVAC problem on the following sites: http://hvac-talk.com/vbb/forumdisplay.php?f=1 and http://www.diychatroom.com/f17/ I found the professionals there to be extremely helpful, and their advice turned a recommendation from a technician to replace my furnace into just fixing a badly installed water drainage pipe (The shin bone is connected to the thigh bone in HVAC also!). In the meantime, I assume that you have your furnace in your basement. Do you at least have the fan running constantly so as to circulate the cool air from the basement to the rest of the house?
Re your Vizio, yes, I found that the new $1000 plus LCD TVs should be regarded as short-term (i.e., one year plus a day) disposable items! Must be a sign of growing old, but, that happened over a year ago, and I still haven't been able to wrap my mind around it, particularly as I have other 20+ year old TVs chugging along just fine! Sorry to piggy-back onto your rant, but my experience is that this digital revolution has been a giant con on the consumer, unless you're willing to shell out a lot more money than you did before!
Carole, I understand planned obsolescence, but what I'm experiencing more and more is just lack of the most basic quality-control.
OK. Rant over!
Re:John- its stinkin' hot here also, but ......
JamieDonaldson
... the A/C is doing just fine!
Maybe it's not the way they make them... *LINK*
David Walser
John,
With so many things breaking, have you considered that it might not be the quality of the individual units that's at fault? Maybe it's user error?
I'm joking about user error, but I wonder whether the electrical supply to your house suffers from unusually large and frequent power fluctuations. It seems many of of the products we use everyday are more sensitive to such fluctuations and our power grid is less reliable than it once was -- which is a bad combination. Small power line surges may damage the electronics inside an appliance without your noticing either the surge or the damage. You just know your printer suddenly quit working -- a year or more after the unnoticed surge.
Is your home protected from power surges? If so, is the surge protector still working?
This Old House article on surge protection
Dick Hines
Re: Maybe it's not the way they make them...
Dick Hines
This must be AC blow up month. Mine went out on the 5th. After sitting out in the heat at a farmers market it did not take me long to figure the AC was not running when we got home. I call the repair guy and left a message. He call Sunday morning and said his son was on the way. The compasator was bad. He had it fixed it about 15 min.
It was 88 in the house and took all day and into the evening to cool down.
I am not getting along with compasators lately. The one on my dust collector went bad last month.
I don't know how we lived through the summers when i was a kid. We had no AC, just fans.
Except Cars...
Wally Dickerman in Arizona
My 2004 Toyota has 115,000 miles on it. It doesn't use a drop of oil. Except for maintenance, it has never needed repairing. It's on it's second set of tires and it's third battery. And it runs just about like a new car. No squeaks, no rattles. Good gas mileage...
A 1950's car with 115,000 miles would have had at least 2 ring jobs and valve jobs and it would still use oil. It would need frequent tune ups. Points, plugs, etc. The usual carborator problems. Lots of repair jobs on the electrics, probably an expensive transmission repair. It would have used up several sets of tires. It would have many squeaks and rattles. And it would run like an old car. It would get poor gas mileage. and on and on...
David Walser
Making it through summer without AC was easier when I was a did. For one thing, we didn't live in Arizona...
Bart Leetch
My AC NOT don't have any. 72 inside 61.8 outside Oak Harbor WA. Sometimes in the last few days with a strong breeze a coat feels good.
Re: Except Cars...
Texian
Good point Wally. If I had a dollar for every set of plugs, points, and condenser I've changed I could afford to retire. Well come to think of it, I did retire about the time I got to quit changing all that crap.
Re: Except Cars...
Russ Fairfield
I agree with Wally. We have never had it so good when it comes to automobiles and reliability.
My '99 Chevy 3500 truck has 105,000 miles on it, about 40,000 of them pulling a 30' 5th wheel trailer, and it has never had the first maintenance done to it other than replacing the battery twice and the brake pads after coming down the hill from Flagstaff to Phoenix, and it is nearing the 2nd tire replacement. Sometimes I complain about the 10 MPG, but not a lot. After all this is a 454 cubic inch engine, it has been good and reliable, and it gets the same mileage running empty, fully loaded, or pulling the trailer up that same hill on a hot AZ day.
My 1st new pickup was a '56 Chevy 6 cylinder 1/2 ton with manual shift. It got all of 12 mpg on a good day and downhill, and those new hydrauloic valve lifters started rattling after 1500 miles and only got louder with time. The best OK Rubber Welder 6.50X16 retread tires were good for about 5000 miles, but at $20 apiece they were all I could afford. The engine required frequest maintenance. Plugs, points, and condenser every 5000 miles, and a new voltage regulator was always a good idea at the same time. It still broke down on me twice in the middle of nowhere with electrical problems when I tried to run longer than the 6000 miles. . Fortunately I was able to get it running again both times with a piece of wire and a hair pin. I got rid of it at 60,000 miles because it was totally worn out. Everything rattled and it burned a quart of oil every 100 miles. Yup, as Wally said, those were the good old days.
Mine do...
Tony - Memphis
I never turn them unless they need it (which is rare), but the rotors on our Nissan and our Chevy can be turned. Now,the Nissan "mechanic" turned one set way too much and they can't be turned again, but they have't needed turning (didn't need it the first time). I usually do the brakes myself, but my wife was at the dealer with the car and the price was right, so I let them do it. No more! Anyway, my old mgr is a brake engineer (used to be Delphi, but now it is Bejing West Industries). he said that most rotor turning leaves the rotor is worse shape than it was anyway. Our Nissan Z eats brakes....and tires.
Tony
bill crommett
Bart is a spoil-sport
Re: Nothing holds up anymore INSURANCE
woodspinner
Hey all
You should consider an American Home Shield plan. I can not remember the price but I tink about
$ 465.00 per year with a $ 65.00 deductable per service. It covers almost everything in your home except electronics. I have used them for years, on several homes. I feel we get our moneys worth and piece of mind knowing there will be no unexpected big bills. They either repair or replace the failed item.
They also take payments for the insurance.
