Hand held laser (possibly) for surface decorating *LINK*
Craig Daymon
Saw this laser reviewed on Slashdot (a technology/computer news site). It looks like a light saber and has a 1w blue laser that WILL burn. (WARNING - can blind as well as burn skin.) It retails for $200. Not dirt cheap, but less than the $2,000 the same device would have cost a year ago.
Might make an interesting way to sign your work. Also, mounted to different fixtures, might be able to burn some precise patterns.
-Craig
Spyder III blue laser
Re: Hand held laser (possibly) for surface decorating *LINK*
Can you imagine doing a demo with that?
Everyone would have to be issued safety glasses upon entering and probably sign a waiver at the door. Anything in the room sensitive to this kind of light would have to covered including fire and smoke detectors.
When you fire it up you have to utter the "aaaargh aaaargh aaaaargh" sound. Charlie will probably have one order before I'm done typing this.
Steven Antonucci
Don't confuse it with your laser pointer...
Steven Antonucci
"You in the flaming flannel shirt...oops, sorry about that..."
I love the words "instantly set fire"... makes me warm and fuzzy.
Charlie ordered 2, and he's turning two robots powered bowls with finials made from these things... he's going to bring back BattleBots, only with laser weaponry. ;)
S
"Dangerous" is a serious understatement!
Texian
Re: "Dangerous" is a serious understatement!
John Jordan
Seen in lab
WARNING: Do Not Look at Laser with Remaining Eye!
John
Steve Kubien
Steve Kubien
This is a club demo I will NOT be attending.
Just to be clear...
Craig Daymon
... I never said ANYTHING about using this in a demo.
I think there are some applications for this with respect to surface decoration, but all cautions should be observed. (In fact, might be a good idea to put an elastic strap on the glasses to make sure they DON'T accidentally fall off.)
-Craig
Steve Kubien
Crystal clear.  No worries.
Steve Kubien
Checking with an eye doctor re: "eye protection
charlie belden
When playing with lasers, especially 1W or more lasers, figure it's better to ask an eye doctor about eye protection rather than rely on info found on the internet. So I asked my eye doctor about eye protection when using a laser. If I provide the wavelengths of the lasers I'm interested in he's offered to research what eye protection will be required to protect my eyes. Will also find out if whatever he comes up with can also be machined for a shield right around where the laser beam is shining. What I have in mind is to make it a pressure switch that will only turn on the laser when the eye protection shield is depressed - against a surface - like wood.
If anyone here is thinking about making and using a laser "pyro tool" - I'd strongly suggest you get the specifics for the laser you want to use and check with your eye doctor about what you need to protect your eyes.
Re: Checking with an eye doctor re: "eye protectio
Don Evans
Understand that any lens (glasses) that will protect you must cut out the wavelength that the laser works with. That being said, also understand that you will NOT be able to see the laser light at all. There then becomes the problem of where is it pointing on the wood so how you gonna tell how to write anything with it or make marks where you want them, etc etc.
This laser would not burn you, but would blind you and it was a problem to adjust the mirrors etc involved. One mirror sat on a galvo shaft and it caused the laser light to scan the paper. Techs did the alignment in a dark room but there was no way for them to protect their eyes cause the had to see the beam to make the adjustments.
I've worked with lasers since mid 70's. These were used to reproduce photo's on special paper that was developed with heat.
We produced these machines from scratch (never before done) and had 3m make the paper for us.
These machines were not for public use.
I don't see any practical way to use a laser for pyro, not yet anyway.
There is one way, but as said not practical. You could do the work in a blackened cabinet, only your hands and arms in it with the object to be burned then a camera and monitor to see the object and laser beam. But cheaper to use a Detail Master or Burnmaster for now.
Don
Laser Burning Wood Can Be Done In Desk Light *LINK*
charlie belden
One of my dOntists, not to be confused with dEntist, had a pulsing laser "drill" unit - with TWO drills attached to one base unit - and it was hand held. One laser "drill" would vaporize tooth material WITHOUT affecting gum tissue adjacent to the tooth - and another that worked the other way, varporizing gum material but not tooth material. And I know there are laser "scalpels" which "cut" and cauterize tissue and blood vessels. Neither require working with them in a dark room and both require seeing where the cut/hole will be made BEFORE the cut/hole is made.
While it is true that laser light can't be seen - while passing through a vacuum or clean, dry air - it can be seen when reflected off a surface - be it dust particles in the air, "smoke", or tiny oil or water droppets generated by "foggers (like used in club laser shows). The trick for using a laser as a pyro tool would be to exploit "Beam Diameter" and "Beam Divergence". Beam Diameter would determine the smallest "dot" that could be burned, Beam Divergence determining how much the beam will spread from source to target. The more the beam diverges over distance, the less energy occurs at any given point. If you can get close enough to see about where you're GOING to burn - then move in closer to the surface to be burned - you'd could get close enough to actually start burning material where you intended to burn material. Once the burning starts, you can see THAT. It's starting the "line" that's tricky - seeing where BEFORE initiating burnin. Of course a visible red laser beam could be used as an aiming method to locate the burning laser's location on the piece.
The video of a hand held laser burning wood shows that it can be done in a desk top lighting situation. The beam on the wood is clearly visible before burning begins so the distance to the wood's surface CAN be used to control when burning begins vs getting visibly close before burning. Attached is the link to that video in case you missed it.
Lasers have come a LONG way since the 70s.
laser burning wood in desk top lighting
Re: Laser Burning Wood Can Be Done In Desk Light
Don Evans
I know all that, you missed the whole point.
The subject was using glasses, actually should be goggles to protect the eyes based on wavelength of the light.
That was what I was addressing and nothing else.
However, I did come up with a way to do that. If one has a unit that also has a regular light build in that points to the spot where the laser would hit. THEN you could use the goggles that cut the laser wavelength out and use the regular light as a guide.
Apparently I don't have as much time as you do, go make one....
Don
