Exploiting Expectations
charlie belden
One of the things that makes a piece appealing - is its ability to astonish us.
Astonish: to greatly impress or surprise.
I've seen a large number of really impressive pieces here and over at WOW. Aside from the beauty and often visual complexity of these piece, the skills and abilities required to make such things alone is impressive. Some of these pieces impress because of their high "I Wonder How This Was Done?!" factor.
The SURPRISE astonishing pieces, the ones that trigger smiles - or pleasant confusion and then a smile or even an out loud laugh - are - surpisingly - rarer. Now it could be that static pieces or even static still images of a dynamic/kinetic piece are unable to convey the SURPRISE. Somehow, Alby Hall and a few others regularly pull off SURPRISE - really well - with static pieces - and Still photos of them.
Maybe videos, with sound, might bring more of these types of pieces "out of the closet".
Maybe SURPRISE pieces have a negative connotation - seen as a gimmick, sophomoric, unelegant, not aesthetic, "just not proper" - so not even considered for a future piece. It is conceivable that "impressive" AND "surprise" could both exist in a single piece and someone here or elsewhere has the skills and abilities to do such a piece. Peter Rand, for one, has done it, or gotten very close to doing it. Besler will probably pull it off as well. I'm sure there are others making sketches and rounding up parts for a SURPRISE idea out there as well. ( Come out, come out - wherever you are!)
Oddly enough, surprising people isn't that hard to do. One of the ways to surprise people is to Exploit Expectations by having a piece DO SOMETHING UNEXPECTED. Doing a Pleasantly Surprising piece isn't difficult to do - though it can be - if you choose to make it difficult
Me, I really enjoy figuring out ways of incorporating an element of surprise in many of my pieces. Coming up with ideas is fun. Figuring out how to do them is fun. The process of making them is fun - most of the time. And it's fun to play with a piece that works as it's supposed to. Hell, even ideas that don't turnout as expected usually yield ideas for other, potentially fun - and surprising - pieces.
Case in point - the hollow form I'm thinking about using for a Stamp Controller (Arduino) controlled. battery powered, motion detecting, glowing RGB LEDs and/or servo driven movement and/or sound generating and/or solar powered piece - has been used for two earlier "failures" - a Bot Sugar Bowl and a MagLev Hollow Form. If I can figure out how to get the electronics to work as I want them to, this hollow form may become part of my first micro computer controlled dynamic/kinetic piece.
Attached are two ideas for potentially "astonishing" pieces. The first is a variation of a piece I've already done - using a ball and socket penduluming finial on a Hyper Ellipsoid lidded box. The second idea using a battery powered stamp controller has already provided a bit of fun learnng about what a stamp controller and some "actions" parts can do - and how to get them to do it. I've already started a stamp contoller controlled prototype out of 4" ABS pipe and have turned the parts to hold the electronic components in place. Now I just need to prototype the electronics on a "breadboard", develop the "sketch" (software) to make things work and maybe - just maybe - there'll be a YouTube video of a piece when it's done.
Here's the Wild Hare Ideas Prototype Bench - with most of the "stuff". Have only burned myself ONCE - so far ; )
Have YOU done, or considered doing, a SURPRISE Piece? If so, care to share?
