Veritas - Innovation in Tools
Test Picture Link---- Grinder Eye Candy *LINK*
Leo Cuellar in Custer, Wa
I've seen very impressive vids of what a skew chisel can do in the hands of someone who knows what they are doing. I've read very good threads here that pointed me in the right direction, but I still couldn't get it right={ I've been tinkering with this line shaft grinder for a year or so. Tonight I finished the latest round of modifications. Finally, I was able to get a nice clean consistent grind that I couldn't get on the big tools before with the ill conceived tool rests I had first made. Wow, what a difference!
So I wanted to see if I could link a pic of the grinder from my Windows Live space. Critique is welcomed.
http://cid-dea1f1038ac49190.photos.live.com/self.aspx/THE%20GRINDER/DVC00322.JPG
Re: Test Picture Link---- Grinder Eye Candy *LINK*
I like your tool rest. As an Auxilliary grinder for my other needs it would work great. It wouldn't work for me because 90 percent of my grinding is done with the V arm on the Oneway system.
Figuring out a gouge attachment will be the next step, I've been looking at different setups.
Don Evans
Leo, that's rather impressive and obviously a lot of work went into it.
One comment on the white wheel, you are aware that when it gets loaded up with metal filings like the one in the picture it reduces the cutting efficiency of the wheel a lot?
You need to keep it really clean with a diamond, you don't need a fancy one, I have the oneway truing attachment but don't use it, instead just a "T" handle one with diamond chips on the end of it, cost about $6.00 or so.
Don't use the white wheel for shaping, use it for sharpening after it is shaped with a regular wheel. The point here is that I see a problem with turning tools anyway in the different diameter of your rough wheel as compared to your white, they would be better the same diameter.
You may know all this, hope some of it helps.
Don
Hi Don. Thanks for the diamond tip, I have the old style steel point dresser, but I do have a coarse diamond file that will probably do the job until I get one. Yes the different diameters are a pain to adjust the angles for, just trying to use up what I have. I specialize in low budget tinkering;) I have to figure out an effective guard also.
Leo
Great looking set up.
I noticed you skew appears to make out of an old file or rasp. ?????
If it is, did you retemper it? While they are good steel, they are too brittle and need to be annealed. If you break one using it, the shards can be very hazardous.
Hi Barry. Guilty as charged:( I did re-temper it though:) I was following a non-committal semi-recommendation from a very old Peter Child book. I do keep the rest as close as possible to the work. You probably also saw the pic of the leaf springs, which the next generation of tools will be made from. Long and strong, which was a real point he made. I hope to start cutting the blanks this weekend=] I can hardly wait!!
Leo Cuellar
Thank You Ellis!!! You ARE the man.
Leo Cuellar
Thank you again Ellis, for taking the time to help me get that straightened out.
Leo
Glad it worked out
Leo Cuellar
Thanks for all the tips everybody!!! *LINK*
Leo Cuellar
Thank you guys. Your feedback was very helpful. You inspired me to get the next part of it done today. I now have a gouge grinder attachment built and tested. Now I can get a smooth grind on those as well. Yes, most of those are homemade as well :D
Leo
The Grinder
Re: How About A Guard?
Barry
I hope the grinder will have a guard before it goes into daily use. Although we tend to think of the grinder as a very safe tool, they can be deadly if a wheel breaks and comes apart. Centrifugal force, even with a slow-speed grinder, can be tremendous. A flimsy plastic face shield would add very little safety.
