Serendipitous Swivel Joint Idea
charlie belden
Must be something in the air. This is another example of Synthesis - and serednipidous synthesis at that.
I'm playng with an Arduino "stamp controller", fiddling out how to use sensors to activate actions - lighting up LEDs, buzzing a little buzzer and controling a servo. While playing with getting an infra red sensor detecting movement to then buzz buzzer, I turned a "funnel" to put over the buzzer to "amplify" its sound (Serendipitous element #1).
I was thinking about using the Arduino in a hollow form - with an infra red detector to spot movement nearby and then triggger LEDS, RDG LEDS, a piezo electric "speaker" and maybe a servo to add movement.
I'd turned a hollow form intended to go over a hidden light and sound activated micro-robot which would cause the piece to crawl away when touched or startled by a loud noise - like a hand clap. I wasn't able to get its weight down to the micro robot's carrying capacity but kept the piece on a shelf. Tried using it again for a Mag Lev idea - which also didn't work out using this piece. But - third time's the charm - it would be perfect for a prototype for a "stamp controller" dynamic piece. (Serendipitous element #2).
Wth this hollow form AND an Arduino breadboarded IR detector and piezo buzzer - with the "sound amplifier" funnel shaped "speaker cone" - on my desk next to each other I had an "I WONDER IF . . ." thing happen.
Hmmmmm - that "speaker cone" looks like it's a little larger in diameter - than the opening in the top of the hollow form.. Wonder if it'll fit inside - or if it'll stick up too much? So I dropped the "speaker cone" in the hole in the top of the hollow form - and the rim of the former fit almost flush with the rim of the opening in the hollow form. Hmmmm. . . .
When I put my finger in the "speaker cone" to remove it from the hollow form - it swiveled around.
Hmmmmmmm! If I were to put a tenoned finial down into the "speaker cone" - it could swivel around - remaining vertical even when the hollow form is tilted. And if there were a counterweight off the bottom of the finial's tenon - it could pendulum - like a ball and swivel socketed finial I'd played with earlier.
As luck would have it, I HAPPENED to have a bunch of "spires and spinarettes" that I'd turned a few years back - on hand. (Serendipitous element #4).
So here's a line drawing of the idea.
And here's a cell animation of the hollow form - with funnel and finial that hopefully convey how this idea works.
Comments, questions, suggestions all welcomed.
