Sweet Little Detail Gouge
Jennifer Indy.USA
I finally got around to making a handle for my new little 1/4" detail gouge from Doug Thompson. I wanted a handle that I could take the gouge in and out of for sharpening as well as be able to use some other 1/4" shank home made tools that I have in it. I decided to use a brass reducer fitting that had thick walls so I could tap a hole for a threaded hex screw to secure it. This is the smallest detail gouge I've ever used and after one days use making the details on some new Sojourners I absolutely love it! If you haven't experimented with making your own handles for some of your tools you're missing out. It really is rewarding to make custom fitted handles for our tools. Last year I knocked off the handles of several tools of mine and made my own and just love them. If you hold the blade or shank of most any tool in a bench vise and use a stick of wood against the end of the ferrule and a mallet they pop right off with a few whacks. It's also an easy way to identify each tool quick and easy when they have a different type of wood for each handle. When I travel or demo I toss my tools in a 5 gallon bucket tips down (thick rubber bottom on the bucket) and so having a different type wood for each tool is an easy way to not pick up 3 tools with the same handle before finding the right one!
Doug the gouge is sweet as can be! Bravo!
Pardon the dreaded phone pics.
Jen
Re: Sweet Little Detail Gouge
Steven Antonucci
They also make brilliant shear scrapers!
Steven Antonucci
Mine is 13/32" (seriously, what's up with that, Doug? :-) ). I use it to take very fine shearing cuts... A "must" tool!
steve
Mike Stafford
Mike Stafford
I insert the cutting edge inside the handle when I travel with my tools protecting them perfectly.
I drilled the handle deeply so that I could vary the projection of the tool. If I don't need it to stick out all the way I slide the butt end farther into the handle so I can work with the tool in front of me.
I have handles sized for 1/2", 3/8" and 1/4" tools. The picture shows examples of the adaptors that I bought from Frank Penta. Like Jennifer I have a different wood and in some instances a different handle shape for each tool.
Love 'em!!!
Hi Mike, A question for you...
Scott Burr in Ben Lomond CA
Do you know if Frank Penta is still making the inserts? If so, do you have his contact info?
Thanks!
Mike Stafford
Re: Hi Mike, A question for you...
Mike Stafford
Frank actually has them made rather than making them himself. He would be more accurately called a distributor, I suppose. He has them made in 1/4, 3/8, 1/2 and 5/8" sizes.
Try reaching Frank through his website:
http://www.frankpenta.com/sites/penta/
I can't guarantee he will sell to you as he tries to supply our club first. You are certainly welcome to ask....
Dick Hines
Dick Hines
Jen, don't you just love that tool. I picked up one last fall and use all the time.
Doug Thompson near Cleveland
Thanks Jen... your handle is perfect for this small size tool.
Steve, it's .265 which is close enough for a 1/4 gouge... find 10 minutes at the symposium to talk to this poor toolmaker.
Yup, I do!
Jennifer@Indy.USA
Mike, those are very nice, you'll see some from me after the symposium. The handle I made has a bullet shaped nose piece with set screws which can be adapted to this shape by changing a few lines of code... the Haas does the rest.
For making icicles and finials ...
Ed Moore in SW VA
the Thompson 1/4" detail gouge is the best. Whenever I teach ornaments at John C Campbell Folk School I always take enough of these detail gouges for each students. They use them and they love them. The same is true of the 1/4" round skew that I use to make vee grooves on the icicles.
The 1/4" collets like Mike Stafford showed that we get from Frank Penta can handle the slightly larger than 1/4" detail gouge.
Thank you Doug Thompson!
Ed
Psst! Check out the John C Campbell Folk School Auction in another thread.
Mike Stafford
Mike Stafford
I would be interested in seeing some Doug. Have you determined a price point yet?
One of the smart things that was done with the adaptors from Frank is that the part that is inserted into the wood uses a standard size drill which makes it very easy to fit into the handle. The other thing I like is that the set screws are the same size as the set screws on my chuck jaws so the same Allen wrench works for both.
The first tools I mounted with these adaptors were your 1/2" spindle and detail gouges and then the 3/8" spindle and detail gouges. I love being able to adjust the reach in and out so when I don't need much tool overhang the tool only projects a little. And by the way Doug, I love my Thompson gouges. I would have to hurt someone if they messed with my Thompson gouges.
Bill Blasic
Bill Blasic
I prefer a metal handle and I had this one made by Bill Noce. Doug's 1/4 detail is a sweet little tool.
I wonder...
... if it would be an improvement to undercut the step a bit so that it captures the wood fibers and helps prevent splitting, like an actual ferrule does?
Re: I wonder...
George Van Beynen
You have a good idea Ellis!
Steven Antonucci
If I can ever find a room, it's a deal!
Steven Antonucci
Mike Brazeau
Looking forward to meeting you in Hartford and I am sure I will come home with something from your booth.
