Veritas - Innovation in Tools
Lacquer Finish Question
Cgelnett
I have a bowl that I blackened the outside with Transtint mixed with denatured alcohol. After it dried I applied several coats of lacquer and waited a week for the finish to dry. Flip the bowl over and applied lacquer to the other side and waited several day. When I looked at the bottom of the bowl which had been sitting on a paper towel there was a ring in the finish left by the paper towel.
Thinking I did not wait long enough I wet sanded the bottom and re- applied the finish. This time I went out of town for a week and the temperature in the shop was over 90 degrees. So when I flipped the bowl over I put a piece of white paper down this time just in case the paper towel caused the problem and had the same effect as before.
I have used this method on my bowls without the ring on the bottom. So what am I doing wrong this time? Is my lacquer bad? It is hard to the touch and I could wet sand it.
Help I don't like to sand.
Re: Lacquer Finish Question
Dick Coers
How long between the Transtint and the lacquer? I think denatured alcohol has some water in it, and can get trapped under the lacquer. Alcohol will also draw moisture from the air in high humidity conditions.
