Making my own threading tool
Steven Antonucci
Steven Antonucci
Had a few minutes in the shop today and John inspired me to take another run at making a thread chaser. My last one was made from a bolt of questionable origins, and didn't work real well...
I started by getting a grade 8 bolt from Home Depot today. They only had them in zinc coated, so I won't harden it for fear of zinc poisoning. Using a grinder, I ground away about half the bolt's threads, and then lapped it flat on the top with a diamond hone.
It worked "very poorly".
So I went back to the grinder and ground the underside of the threads up to a 45 degree angle, and it worked much better. Once the threads started, it fed the way you'd want it to, but it still cut a "poor" thread.
So I started thinking, "what is the source of the problem?" The wood was cherrry, which is far from optimal, but the threads were very rounded over. When I looked at the bolt, they were pretty round too. Rounded threads chaser rounded threads...
I grabbed a piece of 3/8" tool steel and a 3/8" x18 die. A few minutes later, I had a threaded piece of quality steel (that I could harden if necessary). A few minutes on the grinder and back to the lathe. In a few hours, I've gone from "very poor" to "quite possible"...
Now I just need some good threading wood and a larger die...
Lather. Rinse. Repeat.
S
Re: Making my own threading tool
Karl from Iowa
Corian can be used as a practice material for threading.
R Payne
I've never tried it but on the blacksmithing forums I read they talk of removing the zinc of a galvanized piece with vinegar. Some people have been known to burn it off outside when the wind is blowing. I wouldn't try that myself, but the vinegar reportedly works well.
ron
robo hippy
Go to a flea market and pick up some old tap cutters. Grind off the top and bottom wing, and you have a nice hard cutter. Also, after cutting about half way to final depth, use a soft oil and/or wax in the threads, kind of like what you do to remove tear out.
Allen Batty told me the only American wood fit for hand chasing threads is Mountain Mahogany, and box wood when you can find it.
robo hippy
Steve I clean up the threads with a small jewelers triangular file. I gently run the file down the teeth. I did harden mine. I'm not sure it's necessary unless you cut a lot of threads but it's so easy to do that I just do it any time I make a tool. Then I polish the top flat surface starting with the grinder, then strip sander and then diamond hones followed by stropping. I do most of this before hardening while the metal is soft. I do the final diamond hone after hardening. I also gave them a slight negative rake because I've seen that suggested in a couple of articles.
Perssimon
Jorge Casta�eda
works extremely well too and also dogwood. Even sugar maple cuts well.
Steven Antonucci
You can thread face grain white oak!
Steven Antonucci
Quick and dirty, but a nice thread for the effort. Fit could be 1/1000th tighter. All threading is done with one tool. Left side cuts inside. Right side cuts outside.
Took about 20 minutes to make.
Steve
Re: You can thread face grain white oak!
Steve and others. I think I've found the problem of the box lids not matching up. If you use a bolt the angle of the threads on the male chaser are wrong. Looking at them from the top of the chaser they should run from left to right when looking down the thread. All of the commercial chaser I have do that. They run from right to left on the cut off bolt.
I have refiled them and will find out tomorrow if I'm correct. Mike Hunter stopped in today and we discussed another possibility and I will research that online but it will take some serious reading. It has to do with the angle of the threads being different for small bolts (lets say 3/4" ) vs those on large bolts (lets say 2"). This could also be part of the problem.
I measured my angle as best I could on my commercial chasers and they vary from 1 to 2 degrees off square.
