Black gum Hollow form - critiques invited
Jeff Willaford
This black gum burl was growing on a limb hanging over my shop just begging me to do something with it. approx 4� high x 4.5 � diameter. 5/8� opening. Walls approx �� Waterlox finish. Comments on form, finish and photo are invited.
Re: Black gum Hollow form - critiques invited
Mike Foster
Jeff,
I've turned forms like this in the past, but try to avoid them now. The large void near the center of the form tends to detract from the even flow the eye wants to follow. I would guess that the motivation was to get as large a form out of the burl that you could. I now will decide to turn a smaller form with more solid wood rather than compromise the final result. Sometimes you really cant tell what you'll end up with a burl, but you usually can see the voids opening up as you turn. If you start between centers, you may be able to reorient the wood to better utilize the solid wood, or perhaps get the void away from the center of the form. The form itself is pretty good (slight flattening of the curve toward the bottom) and the wood is wonderful.
Mike
Jeff Willaford
Thanks, Mike, for the good suggestion. I think my motivation was to simply turn this piece as it was something I'd never done before. I like your idea better though and will keep in in mind.
Emmett Manley, Lakeland, TN
I think this is beautiful, but I am but a simple woodturner, not an artist. I love pretty wood and this is impressive to me. Black gum is becoming a rare wood around here.
Jeff Willaford
Thanks Emmett.
Cyril Griesbach
Jeff, good for you giving this as you first attempt. If I were to comment further it would read almost the same as Mike Foster's comment.
Cyril
Jeff Willaford
Thanks Cyril. I appreciate the feedback. I'll definitely take all advice for reference as I try to grow.
