Here's a Concept Example of a "stamp controller" controlled interactive piece that uses sensors to initiate "behaviors" of the piece. The idea uses a ubiquitous hollow form, with "appendiges" as design elements. These design elements are actually portals through which light and sound can travel.
Not very aesthetic and modifications to the "portals" are probably in order - so don't concern yourself with all that. The question is "what do you think of the idea of an interactive piece that uses electronics to permit interaction with the piece without necessarily touching it?
... photovoltaics? Ana, apart from the concept, I'm trying to imagine the possible applications. Brolly et.al's sculpture is one such thought. How many dimensions can you bring to this piece anyway? You could make it move, sing, light up, roll around. I can't wait to see the next installment, Charlie. You're possessed.
Charlie - I think interactive work is fantastic and you seem to have lots of cool ideas in this vein. I've got a number of ideas for work that contains electronics and motors etc. But one thing that always causes a pause for me is the issue of power and durability.
One of the reasons I've been drawn to making the kind of stuff I do is durability. I've spent ~30 years in SW/Computer engineering - that's 30 years of my creative energy. It is safe to say that most of that work is already dead the majority was never commercially viable. The tiny fraction that was out lived it's usefulness within a few years.
One of the things that struck me about the cryptex (one of my goals) is that I could make a functional item (with moving parts) that could conceivably last centuries of longer.
I have not yet found an idea that I like strongly enough to incorporate a battery or power cord into the piece. Ideas that use solar cells or other "self contained" power sources are quite attractive to me. There are currently sensors that can power themselves simply from vibrational energy - but we are talking tiny amounts of power.
I've included a link to for board that I've been looking at for projects.
I'm playng with the Duemilanove (Italian for 2009) version of the Arduino - there are several versions - some quite small but with about the same functionality. In addition to plenty of input/output capabilities, there are all sorts of printed circuit boards available that can stack on the board (they call them "shields"). Some shields are for dedicated applications - for controlling stepper motors and regular motors for example - others are basically breadboards that you can hardwire.
The Arduinos are Open Source and the programming language is a version of "C". The deveopment environment is pretty basic but does have some GUI features for basic functions - New, Compile, Upload, Download and even has a Serial Monitor so you can do a text display and "print"/monitor info about what's going on as the program/sketch is running.
There are a ton of tutorials on how to do a plethora of things, many documented quite well - with clear illustrations and photos, as well as the nicely commented "sketches" that run things - some even include videos with voice overs explaining things. With your experience programming you'll pick up the What Does What quickly.
The beauty of these things is that most of the parts you use can be gotten from Radio Shack, either at a Brick and Mortar store, or on line. And there are plenty of on line stores where just about any electronic chip can be purchased.
As for longevity, these things will run on anything that provides 5VDC or higher, and have no moving partsm if you exclude electrons. That of course assumes no servos, motors and other higher current draw components. Conceivably, you could incorporate small solar panels on a piece and as long as they have a light source, could work for decades. It's making things move that requires power and involves wear and tear. I think there's a way around servos and motors and gear boxes - wire "muscles". These things change length based on current running through them or voltage changes acrossed their ends. That means they can pull on something and cause motion somewhere - essentially an electrically controlled "spring", though they are not wound but are straight.
If 3D means location in an X,Y and Z space, a piece "just sitting" there occupying some of that space, movement can add 3 more dimensions - rotation around each of the three axis. Add sound and you get another dimension - with plenty of range - ultra sonic to subsonic. Add light and you add yet another dimension - again - with plenty of range - infra red to ultra violet and beyond. Now add Time - things changing over time - and you've got another very interesting dimension to play in - movement on any of the 3 axis - lights changing colors, blinking, flashing or fading on and off - sounds rising and falling, changing frequency and volume. And many of these additional dimensions can be controlled - by a little "stamp controller",
It used to be that a piece was "cast in concrete" when the turning was done - assuming that the finish was applied while the piece was still on the lathe. Then folks started doing "post lathe enhancements" - coloring, texturing, piercing, scortching/burning/pyroing. The ideas I'm exploring are merely another step along the "Post Lathe Enhancement" path.
Imagine a piece that is constantly changing, or at least changing while someone is around it. Imagine a piece that adapts to what's going on around it - bright ambient light and it gets "flashy" and maybe sings or purrs - more subdued light and it hums or makes babbling brook sounds, blue and white lights rippling around it as it rocks and sways.
With your background I can envision some pretty interesting "modes" in one of your future pieces. Pick up an Arduino or one of the other "stamp controllers" and play with it for a while. I think you'll discover all sorts of possibilities. When you do - PLEASE let me know what you've come up with.
I found some of his stuff when I first got into woodworking. I loved his sculptural weird pieces - but was into Krenov and cabinet making. Had bookmarked his site - but inadvertently lost all my bookmarks while doing some computer "clean up".. Thanks for the link - he does some REALLY Wild Hare Idea pieces - at a much large scale than I'd even think about doing. But looking at some of his work I'm definitly inspired.
"Possessed" has such a negative connotation, conjuring up images from The Exorcist. I prefer to think of it more like "channeling" - a little of Tesla, a bit of Feynmann , a dab of Bucky Fuller, a touch of Salvador Dali and perhaps a pinch of Gaudi. I'd like to have some Alfonso Mucha in there somewhere - but so far - zip. Adding light and sound provide more dimensions - but it's the addition of time - things changing over time - in response to external stimuli - that these little stamp controllers bring to the playground. It is play that I'm after - and hope to share - when I find some by using this stuff.
I guess I've been doing this channeling thing for a long time. Back in the late 70s I got to use both flat bed plotters and drum plotters in my JOB. And one of my uncles was a sales rep for an early laser company that made things for surveying and putting in sewer lines of all things. My wife - at the time - was a picture framer and she was tediously hand cutting "lace" patterns into some of her mats. I knew a laser could cut stuff, and I knew a plotter could hold a pen and "plot" patterns - so putting those two ideas together wasn't much of a leap of imagination. I've gotten pretty good at "synthesizing" - putting existing things together in new ways.
So I sought out a mechanical engineering prof at a local college and ran the idea by him to see what he thought of it. He pointed out that lasers powerful enough to burn through a piece of mat board were big bulky and expensive - and the stepper motors and electronic controller would also be prohibitively expensive - to say nothing of the needed software and a computer to run it on. He did say it was an interesting idea - not practical - (a the time) - but interesting. Thirty plus years later and kids are making laser engravers - out of old DVD burners, old flat bed scanners and inkjet printers.
Despite nine years of Catholic school, being "taught" by Franciscan nuns - from Austria - and an additional 8 1/2 years of "formal education" focused on engineering, I somehow kept the ability we all start out with to be able to think non-linearly and to ask WHAT IF . . . and then go down some of the resulting paths. And the journey has been fun to this point - and promises to continue to be fun.
I think everyone is born with the "synthesis" ability - but just don't use it often. As a result, many THINK they CAN'T "synthesize". By throwing out examples of "synthesizing" and ways it can be done _ I hope to get someone to activate their own "synthsizing" innate ability - and have fun doing it. And maybe, just maybe - someone like David will come up with something that uses some of these ideas - and make something that's fun - and beautiful - and maybe even aesthetically pleasing - to collectors who are willing to pay to OWN it ; )
