Pyrography - Brown stained edges
jake Niedling
I did some wood burning on a small hollow form. I have some light brown staining along the edge right next to the unburned wood. I think there is a way to clean this up but just can't remember. So I need your help. Thanks, Jake
Re: Pyrography - Brown stained edges
Dick Coers
I use denatured alcohol on a rag to clean up after the laser engraver. Works great.
Barbara Gill
If you don't have denatured alcohol, vodka works just fine. :-)
Isoprophyl alcohol
Molly Winton
91% is the best, but if you can't find any 70% works well too. It's also great for removing the graphite left over from any pencil marks you may have visible.
Terry Scott
I use Acetone you can by from a paint shop
cool
Mike Foster
I found the same problem when experimenting with the wood vaporizer and decided to just paint them all black. I thought the wood had slightly charred/burnt and the only way to get rid of it was rather laborious sanding. I'll give this a try tonight.
Mike
Thanks - It works.  Much appreciate.
jake Niedling
