Boxwood gift ornament
Here is a boxwood gift ornament with hand chased threads. I built some 16 TPI chasers this weekend because I thought the 20TPI were too small and 14 was a little too large. I tried them out on this wood and they work great.
Re: Boxwood gift ornament
threaded gift ornaments
Here are two of the gift ornaments. The top one is maple and threaded with the Baxter threader, the bottom one is Boxwood and is threaded with my new 16TPI chasers.
Steven Antonucci
cool...now show us your threader! ;-)
Steven Antonucci
Re: cool...now show us your threader! ;-)
Sorry. When your busy being the receptionist, part time secretary and photographer you tend to get rather busy on a minutes notice. I was going to post them earlier but you know, they think I should actually work for a living.
These were thrown together with some scrap steel, a 3/4x16 bolt that I cut in half. I welded the bolt halves to the steel. (I have a really crappy welder and I suck at welding) I filed and ground down the welds. Since these are meant to be working tools I only took the time to polish the tip which is the business end of the tool. It probably took about 2 hours handles and all.
Leo Cuellar in Custer, Wa
Nice job with the ornaments! I really love your tools, they look like they came out of my shop. Any weld that does the job is a good weld. I don't get to do as much as I would like. Have you tried clamping to copper plate when you weld?
Welding
Leo there are a couple of problems I have. One is the Welder is cheap and I never know what setting to put it on. The other is, I can' t see. The shield is too dark I think. All I can see is the main arc and maybe some glowing red around the bead but I really can't see how the metal is flowing so I'm doing it by feel.
I bought a better welder this last winter but I have to run a heavier duty 220 line to the shop to be able to use it so for now it's just sitting. Once I know whether I still have a job or not I'll invest in the new wire.
Re: Welding
Hi John, I'm not a pro welder, never took metal shop in school (only wood=), I've found that good light directed at your welding will help you see better, my hood is a little on the dark side too. Its one of those cheap Grizzly auto-adjusting. My day job has a very dark shop=( Finding the correct setting can be hard and is very dependent on the welder in question. I still have a hard time with amp settings too. I mentioned copper plate because its a trick that a real pro taught to me. A nice 1/4" thick piece of any dimension appropriate to the size of your work clamped to the back of the pieces you are welding will act as a heatsink and will allow you to fill in voids & holes. If you like to make things pretty( which I don't worry about for prototypes) round over one edge of the copper & clamp it a little shy of the edge you are trying to fill in. This will allow you to roll the bead from the stick over the edge you are working on without burning those pesky divots. It takes a little extra grinding to smooth down the excess, but worth the effort. I was able to get a good chunk of old buss bar from a scrapyard. I cut it up into various sized chunks for different tasks. I hope the job situation works out OK.
Re: Welding
Thanks Leo, I'll have to try that. In this case I think the voids are simply holes in the puddle where I didn't get it to flow very well. Hard to do when you can't see. During the winter I'm welding at night an I use my quartz lights up close. That really does help.
