I've been working pretty hard on my threading skills lately. Here are some boxes I made to practice. 2 of them have black epoxy threads. One was threaded on the Baxter threader and the small one was threaded by hand chasing.
and I wish I could hold them too. No doubt you covered it earlier, but what is the process for black epoxy threads? Nice photo also. Almost look professional What background did you use?
Jerry I'd like to shoot them more professionally but my time is really short right now at work. I use a seamless paper background. This one is black which actually photographs as a dark gray. By shading the background I can make it go black. I buy them from www.porters.com or any good photo store.
Hal I'm working on 2 ways. One is to simply turn a groove in the wood where I want the threads. fill it in with epoxy, let it dry and then proceed to make the box like normal but I cut the threads into the epoxy.
The other method I like better because it allows for a very small cut between the 2 halves of the box. This helps keep the grain matching. I use a thin parting tools and cut the box apart. Then I add a piece of PVC to form a ring in the middle (cardboard would probably work I just didn't have any) This is just so I don't waste so much epoxy. Then I add tape to the outside so form a 3/8" lip. I fill this area with epoxy. This will then be the male thread. I turn away the PVC when hollowing the box. For the lid I just turn a groove and fill it with epoxy. This will be the female thread.
The epoxy lets me turn threaded boxes with wood that is way to soft chase threads and maybe too soft to cut with the threader.
I did an experiment this weekend with West System epoxy. I used the rapid hardener and slow hardener and then added 3 different types of thickener. None of the thickener cut very clean threads. The plain epoxy both fast and slow cure worked well. I add a few drops of shoe dye to color the epoxy black. The fast cure hardener leaves the epoxy clear and slow cure leaves it amber colored.
