Drill Wizard or precision boring kit ?
Terry Scott
I have been looking at either a Oneway or sorby Drill Wizard or precision boring kit
Which do you prefer and why
Terry Scott
Re: Drill Wizard or precision boring kit ?
Terry I just build my own version of the Sorby using hardwood. It's amazing how long these things last. I've thought about putting a bushing in the way the Sorby does but I've drilled 60 to 80 holes using them and they don't seem to have any wear.
The only thing that wears is where the lock for the tool post pushes against the wood. Of course it takes all of 5 minutes to build one. I use a square piece of wood then drill a hole in the side the size that I need. Turn a tenon for your tool rest and your done.
Richard Allen
I have and have used both products many times. The Oneway prduct is a LOT more usefull. The "Drill Wizard" holds the drill so that amything uou can chuck up in the drill can be used with the drill wizard.
There is a standard size to the business end of corded drills. There are many other tools like the Fein Multimaster which can be attached to the drill wizard. Some of the larger die grinders can be used in the drill wizard.
The "Drill Wizard" has a depth stop which works.
The "Drill Wizard" has a angle scale which I have found effective for drilling holes at specific angles. I needed to dill holes at 4 degrees in the rim of one piece and negative 4 degrees in the base of a smaller piece.
The lever on the "Drill Wizard" makes advancing the drill easy and very controlable.
The sorby tool is simple and effective for drilling specific sized holes.
Setup of either tool is simple an quick. The Oneway tool takes a few seconds longer to setup.
Re: Drill Wizard or precision boring kit ? *LINK*
Mike Brazeau
I went one step further than John and used some bushings from Lee Valley. A writeup at the link.
Index Dill guide
