How do you handle this?
Mike Jones in Redding, Ca.
A fir burl cap with bark inclusions over 1/3 of the surface area (and nice swirley grain around it) with some sanding needed to finish. The bark areas are, of course, very soft in comparison to the sound wood that surrounds it. These bark areas are very irregular in shape, and sanding just up to the margins is just not resulting in a level surface. I'm thinking: coat the whole thing with CA to harden the bark...and hope for the best. Any other suggestions?
Re: How do you handle this?
Sean Troy
Depends how big the cap is. With a reasonable size that you are comfortable with, I would speed up the RPM's as fast as you feel comfortable, use a 3/8 bowl gouge freshly sharpened with a swept back grind. Do a very light push cut all the way through the distance and hold the handle low against your body while doing the push cut. Resharpen and do again until you get your desired look and feel. I have always had good luck that way even on pine burl caps.
Doug Turner
Some people remove the bark with a pressure washer and leave the rough surface natural - especially on burl caps.
Norm Smith
Mike, When I want to save the bark, I do as you suggest. Soak it with thin CA glue.
Norm
Bill Neddow
On soft woods like this with bark inclusions I always use Polyall 2000. You will think you are turning a solid piece of Hard Maple after the treatment. Mix it, brush it on, and it is dry in 3 minutes. It will soak in 1/8 to 1/4 inch -- so if you turn more than this away, you may need another coat. It is a 2-part epoxy and I have kept the unused material for up to two years in as refrigerator. I have yet to find a wood that it stains, like CA glue.
