How long does it take you to make a bowl?
wilbur
I made a bowl last night. It was the first turning project that I had done in a while, since I was occupied with finishing my workbench and doing some needed work on my shop, so I knew I was out of practice.
I took a half log piece of ambrosia maple that had been sitting around long enough that it seemed like I was turning dry wood. It started at about 13" in diameter, and I wound up with a bowl about 10" in diameter and maybe about 4" high or so. It took me about 3-1/2 hours to get almost completely done. I still have to sand and finish the inside, and finish the foot.
Probably since it had been a while, I felt like I was going slower and having a harder time than I remember in the past. It also might be because I was using wood that was far from being green.
Am I being slow?
Re: How long does it take you to make a bowl?
Jeff Willaford
If you enjoyed turning the bowl...what does it matter? I've never timed myself. I'm sure almost everyone turns faster than I do...but I doubt they enjoy it more than I do. Just my opinon.
Bill Howatt
I'd say that I would have done it faster than that but I would have painted the ceiling of the Sistine Chapel at lot faster than Michaelangelo did too - 4 years for a paint job is way too long.
Bill
Peter Charles Fagg (UK)
This is another of those piece of string questions.
If for example I turn my production dishes out of English Sycamore planks which is kiln dried and a standard diameter of 10 inches by 2 inches thick then it takes me about 40 minutes start to finish.
On the other hand if I am turning a particularly beautiful piece of timber that I have chosen especially for a gallery etc. then I could spend several hours getting it just right and worthy of a reasonable price tag.
Judging your turning skills by the time taken is not a good guide, if you are happy with the result and it is within your estimations of time expenditure then it is just fine!
I hope I understood the question correctly?!
Regards, Peter.
Ditto what Peter said . . .
fgvanatta
Steven Antonucci
I can cut one in about 15 minutes
steven antonucci
but you asked how long it takes to make one...
So starting the chainsaw and slicing the log... 5 minutes
Mounting the work and turning the outside 5 minutes if I did a good job with the chainsaw...
Turning it around and emptyng the inside 5 minutes, unless I am coring it, then it's an hour and the bowl ends up 6"...
Demonstrating good technique is one thing, but obsessing over details and finish will probably add an hour or more...
Back when I wasn't a very good turner, things took less time to do, but more time to fix. Now that I am somewhat respectable with a tool, things take less time to do, but more time to do right...
it never ends...
Terry Scott
Does it really matter, to me its about enjoying the process and being satisfied with the result not about how long it takes
If like me turning its a hobbie its often the longer a bowl takes the more satisfied I am
A 15 minute bowl is just that a 15min bowl
No feeling or thought has gone into it
If you enjoy racing the clock thats fine also
Steve Kubien
Steve Kubien
Geez, it depends on so many things... Species, grain, whether I am in a groove... I have done some bowls in the 13" x 4" range go from a dried rough-out to ready for finish in an hour and some more like 4 hours. I've got a cherry one on the lathe right now which will end up being around 14�" x 6" and the outside only took 30 minutes because everything just worked out. It doesn't happen that way all the time. Sometimes I really have to fight to get a nice curve. Other times it comes easy-peezy, pumpkin-squeezy. Arrrgh! can you tell it has been a PA day and the kids are off school?
Just to clarify about the speed thing
wilbur
I'm really not trying to beat the clock. (Well, actually, I need to get some bowls for presents done by Tuesday, but I'll be able to do that.) And I know that it's about enjoying the process, whatever the time that it takes. But it seems that at some level, good technique = efficient turning = less time. So that's why I asked the question -- I felt rusty making last night's bowl, and I thought this would be a reasonable way of figuring out how much out of practice I am.
And I do realize that it depends a lot on what it is that you're turning. That's why I tried to be as specific as possible in my first post. To recap:
~13" ambrosia maple half log to start, mainly dry (not green), turn it down to a 10" x 4" bowl. 3-1/2 hours. Is that a reasonable time?
Do you Know the Difference.....
In a bowl done by you (or me) and one done by Richard Raffan?
About 4 hours. And quite a few bucks too, I imagine.
Steve Kubien
I think so
Steve Kubien
Assuming you round it a bit on the bandsaw or with a chainsaw, I think that's reasonable. Something else occurs to me, it depends on your lathe. I strongly believe I would be faster on a Oneway than my Nova 1624 because the headstock is so much beefier. It would allow me to go faster sooner.
Steven Antonucci
You should be able to knock a few hours off
steven antonucci
Not sure what you are dong for all of that time, but I assume that with some technical improvements and practice, it could be done within an hour to the same degree of finish.
Some of the guys my club bring in things that take lots of time, and I'm always puzzled. I did a demo at the peters Valley craft show last summer where I turned 6 things in about 90 minutes. It's not the speed that matters, but the fact that you do it correctly so you don't need to fix it later.
S
Jennifer Indy.USA
Wilbur it takes as long as it takes. Unless you're a production bowl turner needing to pay your mortgage and feed your kids with the money you make from bowl sales I wouldn't worry one bit if it takes you 3 hours or 10 minutes. If you're having fun doing it then I say make it last and take your sweet time. There's no benefit in turning a bowl as fast as you can. It's more dangerous to rush ourselves and the fun is over before you even get going.
Enjoy the slow and easy pace :)
Sometimes it takes me all day to make a bowl!
Jen
Charles Watson
My current record of being slow is 7 years. I started a manzanita piece and had to stop for reasons I can't remember. When I decided to finish it, the shape did not appeal to me anymore and it was too late to change so I quit again. Seven years later I finished it anyway, and it sold quickly!!
The time it takes does not matter unless you are a production turner, just enjoy what you are doing and do it safely.
Bill Grumbine (Kutztown PA)
Wilbur, there are two questions you need to ask yourself at the end of your session. Do I have a feeling of accomplishment and satisfaction? Am I having fun? That's all there is to it. This stuff is supposed to be fun.
Russ Fairfield
Wilbur, it takes as long as it takes. How long it takes depends on the size, the wood, the turning tools, thickness, your experience, and the finish you apply. It also depends on whether you are doing this for your personal enjoyment or making a bowl to sell to someone else.
Not counting those that are unfinished after months and years, I have made small bowls that have taken less than 20-minutes, start to finish; and I have made large bowls that were very thin that took all day to turn, followed by finishing that added several hours over several weeks. I had fun making all of them, and that is the reason I am astill turning wood.
Lyle Jamieson
Lyle Jamieson
OK, Wilbur, you have asked the question twice, so let me try to respond in a different way. I totally agree that it�s all about the fun. It really does not matter how long it takes as long as you enjoy the process. I can do a bowl in 6 minutes and it may take me 4 or 5, 10 hour days just to plan one of my torso figures before I even get it on the lathe.
With that said, The fun comes with efficiency, and tool control without wasting time and effort. In the routine turning of a bowl it can be done much faster then 3-4 hours. If you can not turn a bowl in half that time you might explore some help with your process and tool control. You should not have to beat your body up for three hours to turn a bowl. Go back up to the first paragraph, do you enjoy the process?? With proper tool control you will never get a catch and the large shavings will peel off effortlessly�wet or dry wood. When the fun starts with good tool control and some significant practice, it opens up whole new level of creativity you could not have imagined. Then the fun will mean it will take longer to do a better bowl.
More time can equal better work. More time should not mean working harder. My 2 cents.
robo hippy
4 bowl cored set from a green blank, prepped on a bandsaw (both for slab and round), forstner bit recess in top, no details, finish turned in about 45 minutes. No face plate, chuck only.
Our club had a challenge of 'anything you can turn in 5 minutes'. I got a 9 by e 3 inch bowl done in just under the 5 minutes. 10 years ago, that same bowl would have taken almost an hour.
One thing that sped up the process for me was not stopping the lathe to look at the wood.
I love scrapers for roughing.
robo hippy
Bill Hale The Wood Spinner
One thing would seem to be the lathe. On my 3 hp Oneway I can realy hog the wood. I rough out the outside and turn a spigout on the bottom. Turn it over, and jaw chuck to finish. I finish almost all of my work with Walnut oil so that also reduces the time. I am a fast production turner.
As you may notice I mention no time to do the work. If you are not doing production work WHO CARES ANYWAY. Enjoy your turning and do not be concerned with anything other than your quality and most of all your enjoyment of what you do.
It's about fun-and safety.
I will certainly agree with the others. It's all about the process and enjoying it. I occasionally get hung up on how long is it taking me to do "this" and how can I get my money out of it. It takes the fun out of it and it becomes a job.
You can turn fast but safety should be foremost on your mind. Efficiency of tool use is the best way to get fast. Just cranking up the lathe speed may lead to a serious accident.
Probably the best way to get fast is to turn a lot of the same thing. Not just a bowl, but the same bowl. Doing this teaches you to get to the final shape faster, you don't have to stop the lathe as often, and you don't have to stop and say "what's the next step".
I can't give you times on bowls because I don't track it. I can tell you that when I first started turning hand mirrors the plain ones took 4 hours or longer and I was exhausted by the time I got done. Now I turn those in 45 minutes or less and I'm having fun and I'm relaxed. On my high end mirrors I've taken as long as 10 hours to cut, carve, paint, texture, etc. On those it's just for the enjoyment of doing something fun so I don't worry about the time.
72 yrs  8 : )
gary clarke
How long to turn a bowl
Barry L Elder
I don't know whether it's that I am turning tropical woods or that I am a romanticist, but it can take me years to finish turn a bowl. When turning a Seagrape bowl, the longer I take, the deeper the red-orange color. Some of the woods cause me to sneeze if I forget the respirator, but I still stop every now and then to observe the grain and character points. But I truly enjoy each and every one and still love the natural beauty of the wood!
