Buffing with tripoli
Jim Rutten
Good morning,
A question just popped into my head and I thought I would lets you guys and gals answer it since you are SO DARN GOOD at it. My normal finishing routine in the past has been Watco Penetrating Oil (around 3 coats) followed by buffing with Tripoli, White diamond, and Renaissance wax. It occurs to me, after recent discussions and classes, that this might be the incorrect order. I've been told that Tripoli is not a finish at all but instead a polisher that gets out some of the sanding scatches, so I am wondering if the order should be Tripoli, followed by the penetrating oil, followed by the white diamond and renaissane wax? All opinions are valed and I will check back in at about noon to harvest your answers (boy you can tell I'm from Kansas, can't you).
Re: Buffing with tripoli
Barbara Gill
As far as I am concerned you are using the correct order. I really don't think the Tripoli gets much in the way of sanding scratches out. I also use a penetrating oil. The Tripoli gives it a nice luster, the white diamond seems to clean the Tripoli residue off and then the wax.
If you buff with Tripoli before the finish I would think you would run the risk of burnishing the wood which would reduce the absorption of the oil. This would for me mess up the oil application as the penetration is important to the correct use of yte oil I use.
Jim Barbara is right. The tripoli and White diamond are polishing compounds. They have a wax binder to hold the abrasives. This can cause problems with some finishes.
Tripoli is a very fine abrasive and it is used primarily to condition the finish not to remove sanding scratches although it will do that if you apply enough abrasive for long enough. Think about trying to remove 120 grit scratches with 600 grit paper. You can do it but boy is it a chore.
Apply your finish first then improve the finish with finer grit abrasives. On large vessels I often do the final polishing by hand using various automotive polishes. They accomplish the same thing but are less likely to burn through the finish.
I was planning a visit to the Gibson guitar factory to talk to their buffing experts to learn more about buffing. That fell through temporarily due to the flood. When they get back up and running I'll talk to my friend again and plan a visit and hopefully learn some things I can pass on.
Russ Fairfield
Tripoli is Jewelers Rouge and as such it is about the equivalent of using 900-grit sandpaper. Most sanding scratches are left over from the coarsest grit you used. Often they are not seen until the wood is polished enough to reveal them. You will be polishing forever if you are trying to use the Tripoli to remove enough wood to get rid of the sanding scratches that were left from the 150-grit.
The way to do that is to bite the bullet and go back to the 150-grit and then remove all of the sanding scratches from the previous grit before going on to the next grit, and this will be faster if you don't skip any of the grits.
Bill Howatt
I agree with Barbara. Also, the waxy binder from the Tripoli will also coat the wood and inhibit good penetration of the finish.
The buffing process is intended to work on the cured finish - the underlying wood should be in good condition before it is applied. When dealing with workpiece flaws we all secretly hope the "finish will make it better" even though the usual result is the "finish made it worse".
Bill
Leo Cuellar in Custer, Wa
I haven't tried using tripoli on wood yet (too chicken=), but I often sand to 1500 grit which really highlights scratches btw. I usually raise the grain a couple of times before 600. It does bring out the figure nicely. I usually try for a minimum 10 coats of tung oil cut with low odor mineral spirits. I have heard however that it will dry faster with turpentine. So anyway, I'm curious about the tripoli too.
Jim Rutten
Thanks everyone. That is the answer I expected and I have been getting good results with my current methodology. I just wondered if I was missing something. Just FYI I always sand through every grit and, in fact, use some grits not normally used. Thank you. :)
your sequence is correct
bob davis
what about guitar makers?
Don Evans
John
A suggest would be to go to the people that work with wood who have perfected this process IMO.
That would be Steward MacDonald the guitar making folks, they have a full line of polishing products that fit our needs.
www.stewmac.com
All of you have seen the finish on guitars, cannot get it any better than those.
Don
no affiliation to stewmac
