Iron Maiden
Iron Maiden
Iron Maiden
Terry Scott
Not often but sometimes a piece just gives you the vibes this was one of them
Its made from Iron Bark with Black palm as the lid and Cocabola as the finial
First time I have turned this timber what a dream
Thanks Michele and Darrel Pointon Ill be around on the weekend with cheque book hoping you have some more
I have to admit to having 3 or 4 goes at a finial until I ended up with this one
Trying to get the work balanced and to flow through the lid and finial was an act
Why the big opening well it seems I can no longer enter My finial boxes into Box categories at shows as they no longer comply. A box know has to be able to have something placed inside. The big hole did allow me to finish the inside to 1200 grit the same as the out side However allot harder to keep the form from losing it
4 � inches square
What do you think ?
A better name if you have one would be appreciated
I hollowed this by using my brand new Mini Kelton Hollowers for the first time (slap my wrist I brought them a month ago )After Eli Aversera stayed for a week and I played with his .I have found that I can really get in through some small holes
I then used my negative rake scraper I have made so the small ridges left in hollowing were easily removed little sanding was needed as this stuff cut a dream
2mm thick in the walls
I sanded with paraffin oil to prevent over heating
This piece is turned cross grain so the wings retain the strenght with support of the fibers Yes the wings were turned with the skew between centers
Re: Iron Maiden
Re: Iron Maiden
Matt Overton
elegant, as usual. The finial was worth the effort, it works with the piece beautifully.
Re: Iron Maiden
I agree with Matt - terrific piece
Jeff Willaford
Re: Iron Maiden
Re: Iron Maiden
Bob Macgregor
Nice piece.
Let's see...that's an iron maiden...if two of the four corners were turned up, would it be a Marilyn Monroe?
BOB
Re: Iron Maiden
Now THERE's An Idea For A Piece
charlie belden
Re: Iron Maiden
Steven Antonucci
turn and carve an Eddie finial?
steven antonucci
If you truly want to make an Iron Maiden piece, it will need an Eddie finial.
I turn to Iron Maiden all of the time. Hard to not air guitar on my bowl gouge...
Non-obvious metalhead.
Steve
