We are doing some church remodeling. We have to drain and remove the septic tank and hook up with the county (city) sewer. The Ginkgo is near the septic tank system. The roots for the River Birch were disturbed and they weren't looking good. I got them to give me a couple of 2' lengths of birch.
If the Ginkgo doesn't make it - is it worth turning??
Re: I figure the River Birch will be okay, Ginkgo??
Terry Quiram
Ginkgo is very nice to turn. It is fairly stable while drying and shear scrapes like a dream. It also sands well. Not much in the way of interesting grain.
I'm just trying to be prepared. I'm realistic - if you disturb an older trees root system - it often will die. I just know how close it is to the septic lines and tank - that's why I'm going to be prepared.
From the fan shaped leaves to the way the twigs grow out at almost a 90 degree angle and look like cigarettes. My wife, whose degree is in horticulture, says when she dies she wants to be cremated and her ashes used for fertilizer for a ginkgo biloba tree. Good luck on keeping it.
As with any living thing, the better the health before surgery the better the outcome. Pre fertilize, be sure to keep well watered and possibly do some pruning to reduce the overall foliage. Most times where root pruning ocurres the stress will follow on that side of the tree. If there are some very large roots on that side possibly try not to cut them. Carefully dig around them and put the drain pipe under them. After trenching trim the roots to a clean end powder with sulfur and let them dry a bit before backfill. TLC
