Think I've Found A Way To Permit Interaction
charlie belden
There's a reason for LOOK - BUT DON'T TOUCH pieces - finger prints, accidently dropping a piece or banging it on something, scratches and oil from someone's fingers.
But there ARE ways to allow people to interact with a dynamic/kinetic piece - without actually touching it - electronics - little battery powered, unobtrusive electronics. There are all sorts of electronic sensors that can detect movement, infra red from warm bodies, pressure, vibration - and changes in light.
Imagine being handed a small flashlight and being told "use the flashlight's light to move that piece. Shine it on the left side and the piece will rotate to the left. Shine the light to the right side of the piece and it'll rotate right. Shine the light up near the top of the piece and it'll lean towards you so you can see inside."
Imagine a display shelf of pieces - all turning Towards The Light in unison. Maybe you could use the light to "conduct" a small choir of sound generating pieces - their "voices" going UP when the light goes up, DOWN when the light goes down, . . .
Imagine an elegant turning - giggling when you "tickle" it with a beam of light.
Interactive pieces - without ACTUAL contact.
Stuff to do all that is available now - and not at all expensive to get into - unlike like turning.
Re: Think I've Found A Way To Permit Interaction
Frederick Nelson
Your description of voices rising or falling in pitch with a beam of light suggests that this could be done with the simple capacitance of your observer's hands. Incorporating a Theremin into a turning should not be difficult; even its antennae (one for volume, one for pitch) could be hidden or exposed. Adapting the Theremin's output (normally sound) into motion or other activity (getting turned "flowers" to follow the movement for instance) should also be possible. I suspect it would take a serious electronics technician to conjure up the necessary circuitry, but it would certainly be possible.
Fred
No overnight storms forecast in Eastern Missouri
Re: Think I've Found A Way To Permit Interaction *LINK*
charlie belden
Fred:
Actually, it won't require Electronic Technician certification. "Stamp Controllers" (little computers on a chip) are cheap. As a kit that you have to solder the components onto a little PC board can be had for about $15. For $25, you can get one fully assembled with a USB port for communicating between computer and stamp controller board. You can get little light detecting resistors 5 for $3, all on a little PC board infrared detectors for around $7 and little stepper motor servos start around $10. The programming language is a simple version of "C".
Type in "Arduino" in the search box on YouTube to get an idea of what people are doing with this little gizmo. Tutorials, with step by step instructions, diagrams for what wire go where and downloadable "sketches" (programs) to make the sample circuits work can be found at ardx.org.
It ain't Rocket Scientist stuff anymore though there is a learning curve. But when it's fun, it's more like taking an interesting little hike rather than like climbing mountains.
Imagine a DO NOT TOUCH piece - sitting on a pressure sensitive hidden pad. A curious person - who doesn't seem to be able to read signs picks up the piece. A Darth Vader voice immediately says "PUT ME DOWN - AND STEP AWAY!"
example instructions of light detecting resistor
Terry Scott
Better be careful make that the locals dont have their automatic door openers tuned to the same frequency
Seriously great idea ,Cannot wait to see what you come up with
