Some work in progress
steven antonucci
Here are two vessels that I started this week. Both were on and off the lathe within 2 hours start to finish. There is some sanding work to be done, but not that much beyond that.
Vessel #1
Spalted Chestnut. This was a very easy vessel to cut, since I made a large opening. It is cut end grain orientation using a hook tool on a 3/4" boring bar. The hook removes a lot of wood very, very quickly. In most areas, I would get 2 or 3 pulls before I had to clear out the curlies. I work about 3-4" at a time, so there was more time with the lathe off than on.
The wood was hard, but soft too (how can that be you ask?) No matter what tool I used, it tore out horrifically. One of the guys fromt the club was looking at the other piece of the log and walked away from it when he saw the chainsaw cut I had made because it was so ragged. When he saw the vessel, he went back out and grabbed part of the log. I told him that the only way he could possibly turn it was if he could use a skew, which is what I made my final pass along the length of the vessel with. There is some torn end grain along the rim that I had cut with a very sharp detail gouge, and I think I'll be able to powersand it carefully. About 13" tall.
Vessel #2
Redwood root burl. Even though my buddy Dan gave me this wood, it wasn't free. Sorta. We split this piece and I took one half and I put the other half in his truck the the club. Embedded in it was a large rock, which I detected with my chainsaw. End of cutting. We knew it was there, and I was cutting around it, right up until the point that I wasn't cutting around it. There's no mistaking the sound of a rock.
I had cut the piece along this rock to include the two inclusions. Nice thing about hollowing vessels with inclusions is that you can measure them very easily AND you clear chips out much more quickly. As a bonus, if your lighting is right and you have a big enough inclusion, you can actually see the tool while the lathe is spinning. Makes work like this very quick.
As it turns out, this vessel also had a couple of smaller rocks that I didn't see immediately. One came out with a gentle tug. The other one, I used my Oneway bowl gouge's built in detector. It goes tikka tikka tikka when you are cutting, and acts sort of like a SawStop for the lathe (blunts the edge so fast , you can't get cut...) After a few minutes on the Tormek, I was back in business.
Hollowed to 1/4" thick more or less all the way down except the bottom, which might be 3/8". The extra weight keeps them from getting knocked over by rampaging kids. 12" tall. Still needs some finish sanding, but pretty clean cutting with conventional tools.
My big debate is on finishing? Hate the idea of touching the whiteness of the Chestnut. Know that the redwood is going to soak up and darken. Decisions, decisions- have been leaning towards sanding finely and being done...
Comments, thoughts, criticism all welcome.
Steve
