"Gear Box"
"Gear Box"
"Gear Box"
Dave Belser
Here is the latest locking box. It is a true locked box made from 44 wooden parts and 120 magnets. Magnets keep coming up on WC so I thought I'd show how I actually use them in this piece.
This is the closed box with the cover on:
The cover has a hole big enough to give you a tease about the inside:
The lid is has a planetary gear set on it that is locked until you dial the correct combination in. Once unlocked, twirling the center handle spins the sun gear driving the planet gears that engage the ring gear. This causes the lid to slowly unscrew itself as it lifts out of the box.
Finally, here is a close up of a planet gear with the knob removed. You can see 6 magnets engaging splines on the inside of the gear, locking the gear.
Unfortunately, because this piece will be in the EOG auction I don't feel that I can put a "please play with me" sign on it - But I'll be happy to demonstrate it if you catch me.
- Dave
Re: "Gear Box"
Steven Antonucci
Um...Wow!
steven antonucci
Having seen your work close up, I can only imagine what this really looks like. Incredible...
s
Re: "Gear Box"
Re: "Gear Box"
charlie belden
Let's see.
IF the center "dial" of each gear has magnets aligned so each repels or attracts a corresponding magnetic "pin" - the gear can then rotate. And if only ONE of those gears needs to be "unlocked" it can rotate, engaging and turning the outer ring rear- which in turn will align a slot below with a pin holding the lid down - so you can . . .
You're well on your way to becoming a Safe Cracker.
Wonderfully complicated, watchmaker craftsmanship - and pleasing to the eye. Not a trivial accomplishment.
So when will you be getting to little electric motors?
Re: "Gear Box"
Barb Siddiqui
Fabulous!
Barb Siddiqui
Re: "Gear Box"
Re: "Gear Box"
WayneLeach - NW Ont
Dave,
Incredible idea and looks like lots of detail work but will certainly be of great interest to someone.
Wayne
Re: "Gear Box"
incredible!
adrien
