Had the opportunity to use the Dennis Stewart arm brace with John Jordan Hollowing tools last weekend. I really liked the feel of the set up.
Does anyone know where to get the Stewart arm brace? Found a similar Sorby for sale, but don't know anything about it? Having only used the Stewart version, I'n not sure that there is not another better one out there. My preference is to buy from the individual rather than a company when given the choice. Any help is appreciated.
...virtually identical, and I don't know if there is a current source for Stewart made tools. The Sorby is available from Craft Supply and Packard in NC.
I have used both the Stewart and Sorby arm braces - I think they are functionally identical - differences are in the rubber hand grip used. I have a Sorby and have been using it for at least 7 to 8 years - no problems with it, although I wish the tightening knob were a bit more ergonomically designed (minor point).
You will find either arm brace to be a good companion with John Jordan or Trent Bosch hollowing tools (among others). I also have the Sorby "Slicer" and a curved end bar for shear scraping. All work well with the Sorby arm brace./
Armbraces are no different than a straight handle as far as safety. You are not "attached" to the handle, it just allows a different, and more relaxed grip/position.
I have used this system for years and find it works great. I like it for deep hollowing and have made a 5 ft x 1 1/2 in stainless bar it. As with any tool be sure you do not exceed your ability to safely use it. The only problem the long bar is its weight and it is tireing to use. Do some and rest. Tired muscles lack good control. With a curved tool it tends to torque to the side so be careful and make light cuts with sharp cutters.
I've been using the Stewart tool since 1987. Never had an injury. I'm convinced that most big catches when hollowing are the result of losing control of the tool in a small catch. Happens in an instant. Using the armbrace helps to keep the tool under control. It's under the forearm and should be tucked in against the users side.
Wally said the most important thing about using the armbrace whether it be be from Stewart, Sorby, or Pencil.
I have seen too many people using the tool with their arm way out over the lathe bed, and they have little control of it when held in that position. Holding the tool close to the body is not always easy to do.
Sorby also missed a point with their version of the Hooker Tool. . The curve is too long and the tool is out past the center-line of the shaft and makes it harder to hold the tool against the tendency to twist. The original Stewart Hooker puts the tip of the cutter on the center-line of the tool and there is little to no tendency to rotate.
Don Pencil didn't miss this point on his version of the tool, and his geometry is correct.
